楼主 #1 2018-08-23 11:51:03
JLINK 命令行如何读取 CP15 协处理器寄存器值?
J-Link>?
Available commands are:
f          Firmware info
h          halt
g          go
Sleep      Waits the given time (in milliseconds). Syntax: Sleep <delay>
s          Single step the target chip
st         Show hardware status
hwinfo     Show hardware info
mem        Read memory. Syntax: mem  [<Zone>:]<Addr>, <NumBytes> (hex)
mem8       Read  8-bit items. Syntax: mem8  [<Zone>:]<Addr>, <NumBytes> (hex)
mem16      Read 16-bit items. Syntax: mem16 [<Zone>:]<Addr>, <NumItems> (hex)
mem32      Read 32-bit items. Syntax: mem32 [<Zone>:]<Addr>, <NumItems> (hex)
w1         Write  8-bit items. Syntax: w1 [<Zone>:]<Addr>, <Data> (hex)
w2         Write 16-bit items. Syntax: w2 [<Zone>:]<Addr>, <Data> (hex)
w4         Write 32-bit items. Syntax: w4 [<Zone>:]<Addr>, <Data> (hex)
erase      Erase internal flash of selected device. Syntax: Erase
wm         Write test words. Syntax: wm <NumWords>
is         Identify length of scan chain select register
ms         Measure length of scan chain. Syntax: ms <Scan chain>
mr         Measure RTCK react time. Syntax: mr
q          Quit
qc         Close JLink connection and quit
r          Reset target         (RESET)
rx         Reset target         (RESET). Syntax: rx <DelayAfterReset>
RSetType   Set the current reset type. Syntax: RSetType <type>
Regs       Display contents of registers
wreg       Write register.   Syntax: wreg <RegName>, <Value>
moe        Shows mode-of-entry, meaning: Reason why CPU is halted
SetBP      Set breakpoint.   Syntax: SetBP <addr> [A/T] [S/H]
SetWP      Set Watchpoint. Syntax: <Addr> [R/W] [<Data> [<D-Mask>] [A-Mask]]
ClrBP      Clear breakpoint. Syntax: ClrBP  <BP_Handle>
ClrWP      Clear watchpoint. Syntax: ClrWP  <WP_Handle>
VCatch     Write vector catch. Syntax: VCatch <Value>
loadfile   Load data file into target memory.
             Syntax: loadfile <filename>, [<addr>]
             Supported extensions: *.bin, *.mot, *.hex, *.srec
             <addr> is needed for bin files only.
loadbin    Load *.bin file into target memory.
             Syntax: loadbin <filename>, <addr>
savebin    Saves target memory into binary file.
             Syntax: savebin <filename>, <addr>, <NumBytes>
verifybin  Verfies if the specified binary is already in the target memory at th
e specified address.
             Syntax: verifybin <filename>, <addr>
SetPC      Set the PC to specified value. Syntax: SetPC <Addr>
le         Change to little endian mode
be         Change to big endian mode
log        Enables log to file.  Syntax: log <filename>
unlock     Unlocks a device. Syntax: unlock <DeviceName>
           Type unlock without <DeviceName> to get a list
           of supported device names.
           nRESET has to be connected
term       Test command to visualize printf output from the target device,
           using DCC (SEGGER DCC handler running on target)
ReadAP     Reads a CoreSight AP register.
           Note: First read returns the data of the previous read.
           An additional read of DP reg 3 is necessary to get the data.
ReadDP     Reads a CoreSight DP register.
           Note: For SWD data is returned immediately.
           For JTAG the data of the previous read is returned.
WriteAP    Writes a CoreSight AP register.
WriteDP    Writes a CoreSight DP register.
SWDSelect  Selects SWD as interface and outputs
           the JTAG -> SWD swichting sequence.
SWDReadAP  Reads a CoreSight AP register via SWD.
SWDReadDP  Reads a CoreSight DP register via SWD.
           Note: Correct data is returned immediately.
SWDWriteAP Writes a CoreSight AP register via SWD.
SWDWriteDP Writes a CoreSight DP register via SWD.
Device     Selects a specific device J-Link shall connect to
           and performs a reconnect.
           In most cases explicit selection of the device is not necessary.
           Selecting a device enables the user to make use of the J-Link
           flash programming functionality as well as using unlimited
           breakpoints in flash memory.
           For some devices explicit device selection is mandatory in order
           to allow the DLL to perform special handling needed by the device.
ExpDevList Exports the device names from the DLL internal
           device list to a text file
             Syntax: ExpDevList <Filename>
PowerTrace Perform power trace (not supported by all models)
Syntax: PowerTrace <LogFile> [<ChannelMask> <RefCountSel>]
<LogFile>: File to store power trace data to
<ChannelMask>: 32-bit mask to specify what channels shall be enabled
<SampleFreq>: Sampling frequency in Hz (0 == max)
<RefCountSel>:       0: No reference count
                     1: Number of bytes transmitted on SWO
---- CP15 ------------
rce        Read CP15.  Syntax: rce <Op1>, <CRn>, <CRm>, <Op2>
wce        Write CP15. Syntax: wce <Op1>, <CRn>, <CRm>, <Op2>, <Data>
---- ICE -------------
Ice        Show state of the embedded ice macrocell (ICE breaker)
ri         Read Ice reg.  Syntax: ri <RegIndex>(hex)
wi         Write Ice reg. Syntax: wi <RegIndex>, <Data>(hex)
---- TRACE -----------
TClear     TRACE - Clear buffer
TSetSize   TRACE - Set Size of trace buffer
TSetFormat TRACE - SetFormat
TSR        TRACE - Show Regions (and analyze trace buffer)
TStart     TRACE - Start
TStop      TRACE - Stop
---- SWO -------------
SWOSpeed   SWO - Show supported speeds
SWOStart   SWO - Start
SWOStop    SWO - Stop
SWOStat    SWO - Display SWO status
SWORead    SWO - Read and display SWO data
SWOShow    SWO - Read and analyze SWO data
SWOFlush   SWO - Flush data
SWOView    SWO - View terminal data
---- PERIODIC --------
PERConf    PERIODIC - Configure
PERStart   PERIODIC - Start
PERStop    PERIODIC - Stop
PERStat    PERIODIC - Display status
PERRead    PERIODIC - Read and display data
PERShow    PERIODIC - Read and analyze data
---- File I/O --------
fwrite     Write file to emulator
fread      Read file from emulator
fshow      Read and display file from emulator
fdelete    Delete file on emulator
fsize      Display size of file on emulator
flist      List directory on emulator
---- Test ------------
TestHaltGo   Run go/halt 1000 times
TestStep     Run step 1000 times
TestCSpeed   Measure CPU speed.
             Parameters: [<RAMAddr>]
TestWSpeed   Measure download speed into target memory.
             Parameters:  [<Addr> [<Size>]]
TestRSpeed   Measure upload speed from target memory.
             Parameters: [<Addr> [<Size>] [<NumBlocks>]]
TestNWSpeed  Measure network download speed.
             Parameters: [<NumBytes> [<NumReps>]]
TestNRSpeed  Measure network upload speed.
---- JTAG ------------
Config     Set number of IR/DR bits before ARM device.
             Syntax: Config <IRpre>, <DRpre>
speed      Set target interface speed. Syntax: speed <freq>|auto|adaptive, e.g.
speed 2000, speed a
i          Read JTAG Id (Host CPU)
wjc        Write JTAG command (IR). Syntax: wjc <Data>(hex)
wjd        Write JTAG data (DR). Syntax: wjd <Data64>(hex), <NumBits>(dec)
RTAP       Reset TAP Controller using state machine (111110)
wjraw      Write Raw JTAG data. Syntax: wjraw <NumBits(dec)>, <tms>, <tdi>
rt         Reset TAP Controller (nTRST)
---- JTAG-Hardware ---
c00        Create clock with TDI = TMS = 0
c          Clock
tck0       Clear TCK
tck1       Set   TCK
0          Clear TDI
1          Set   TDI
t0         Clear TMS
t1         Set   TMS
trst0      Clear TRST
trst1      Set   TRST
r0         Clear RESET
r1         Set   RESET
---- Connection ------
usb        Connect to J-Link via USB.  Syntax: usb <port>, where port is 0..3
ip         Connect to J-Link ARM Pro or J-Link TCP/IP Server via TCP/IP.
           Syntax: ip <ip_addr>
---- Configuration ---
si         Select target interface. Syntax: si <Interface>,
           where 0=JTAG and 1=SWD.
power      Switch power supply for target. Syntax: power <State> [perm],
           where State is either On or Off. Example: power on perm
wconf      Write configuration byte. Syntax: wconf <offset>, <data>
rconf      Read configuration bytes. Syntax: rconf
license    Shows a list of all available license commands
ipaddr     Show/Assign IP address and subnetmask of/to the connected J-Link.
gwaddr     Show/Assign network gateway address of/to the connected J-Link.
dnsaddr    Show/Assign network DNS server address of/to the connected J-Link.
conf       Show configuration of the connected J-Link.
ecp        Enable the  J-Link control panel.
calibrate  Calibrate the target current measurement.
selemu     Select a emulator to communicate with,
           from a list of all emulators which are connected to the host
           The interfaces to search on, can be specified
             Syntax: selemu [<Interface0> <Interface1> ...]
ShowEmuList Shows a list of all emulators which are connected to the host.
            The interfaces to search on, can be specified.
             Syntax: ShowEmuList [<Interface0> <Interface1> ...]
NOTE: Specifying a filename in command line
will start J-Link Commander in script mode.
楼主 #2 2018-08-23 11:55:07
Re: JLINK 命令行如何读取 CP15 协处理器寄存器值?
上面的提示太不人性化了,好不容易找到的指令
读取 CPU Id:
J-Link>rce 0 0 0 0
CP15[0, 0, 0, 0] = 0x41069265
J-Link>rce 0, 0, 0, 0
#3 2018-08-24 18:23:04
zzm24
已发帖子: 114
这个ID是唯一ID吗?晕哥
楼主 #4 2018-08-24 18:30:30
不是唯一,但是可以通过id辨别是哪个芯片.
#5 2019-08-15 20:24:48
linhuaou
已发帖子: 35
这是我的CP15协处理器的值,好巧啊,还是人为设置的?
J-Link>rce 0 0 0 0
CP15[0, 0, 0, 0] = 0x78563412
最近编辑记录 linhuaou (2019-08-15 20:26:03)
#6 2019-08-15 20:30:03
linhuaou
已发帖子: 35
这种读法好像是不对的,这个不是太重要,先研究别的吧
