楼主 #1 2021-05-16 13:38:37
yang
已发帖子: 23
V3S用NS2009电阻触摸失败
用V3S的BSP,修改fex如下
[ctp_para]
ctp_used            = 1
ctp_name            = "tsc2007"
ctp_twi_id          = 0
ctp_twi_addr        = 0x90
ctp_screen_max_x    = 800
ctp_screen_max_y    = 480
ctp_revert_x_flag   = 0
ctp_revert_y_flag   = 0
ctp_exchange_x_y_flag = 1
ctp_int_port        = port:PB02<6><default><default><default>
;ctp_int_port        = port:PG04<6><default><default><default>
;ctp_wakeup          = port:PG03<1><default><default><1>
重新编译下载后显示
[    0.032039] twi_chan_cfg()341 - [twi0] has no twi_speed!
[    0.032066] twi_chan_cfg()352 - [twi0] has no twi_regulator.
[    0.032094] twi_chan_cfg()341 - [twi1] has no twi_speed!
[    0.032117] twi_chan_cfg()352 - [twi1] has no twi_regulator.
QWSTslibMouseHandlerPrivate: ts_open() failed with error: 'No such file or directory'
Please check your tslib installation!
启用ts_calibration 显示
ts_setup: No such file or directory
#2 2021-05-16 14:30:58
已发帖子: 3,379
Re: V3S用NS2009电阻触摸失败
X1000 Linux 执行  ts_test ts_calibrate 都提示 No such file or directory, 求教
http://whycan.com/t_2717.html#p21836
(出处:哇酷开发者社区)
楼主 #3 2021-05-16 15:31:36
yang
已发帖子: 23
不是没有加变量的问题,貌似是TWI驱动的问题,不知道BSP如何修改
#4 2021-08-16 20:44:55
tigger
Moderator
已发帖子: 172
好像不是这里改, 我刚刚搞定了 SPI 触摸屏芯片ADS7846 接 V3s, 全志Linux3.4
