Navigation
    全志在线开发者论坛
    • Register
    • Login
    • Search
    • Categories
    • Tags
    • 在线文档
    • 社区主页
    第一次编译A133 Android SDK,请问这是什么问题呢?
    编译和烧写问题专区
    android
    2
    12
    593
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • tigger
      tigger LV 7 last edited by tigger
      • tigger
        • tigger
          Target buildinfo from: build/make/target/board/go_defaults_common.prop
          Target buildinfo from: build/make/target/board/go_defaults.prop
          Target buildinfo from: device/softwinner/common/system.prop
          [ 96% 82343/85072] //libcore/mmodules/core_platform_api:core-platform-api-stubs Metalava
          /opt/a133/android/external/bouncycastle/repackaged/bcprov/src/main/java/com/android/org/bouncycastle/asn1/x500/style/BCStyle.java:17: warning: Public class com.android.org.bouncycastle.asn1.x500.style.BCStyle stripped of unavailable superclass com.android.org.bouncycastle.asn1.x500.style.AbstractX500NameStyle [HiddenSuperclass]
          [ 96% 82457/85072] //libcore/mmodules/core_platform_api:core-platform-api-stubs Metalava Check API
          [ 98% 83626/85072] //frameworks/base:system-api-stubs-docs Metalava Check API
          [ 98% 83855/85072] //prebuilts/sdk/current/support:android-support-v7-appcompat javac
          [ 98% 83887/85072] //frameworks/base:api-stubs-docs Metalava Check API
          FAILED: out/soong/.intermediates/frameworks/base/api-stubs-docs/android_common/check_last_released_api.timestamp
          ( rm -rf "out/soong/.intermediates/frameworks/base/api-stubs-docs/android_common/last-apicheck/srcjars" && mkdir -p "out/soong/.intermediates/frameworks/base/api-stubs-docs/android_common/last-apicheck/srcjars" && out/soong/host/linux-x86/bin/zipsync -d out/soong/.intermediates/frameworks/base/api-stubs-docs/android_common/last-apicheck/srcjars -l out/soong/.intermediates/frameworks/base/api-stubs-docs/android_common/last-apicheck/srcjars/list -f "*.java" out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/privacy.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/section.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/app/activitymanager.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/app/alarmmanager.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/app/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/app/notification.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/app/notification_channel.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/app/notification_channel_group.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/app/notificationmanager.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/app/pendingintent.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/app/profilerinfo.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/app/settings_enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/app/statusbarmanager.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/app/window_configuration.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/app/job/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/bluetooth/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/bluetooth/a2dp/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/bluetooth/hci/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/bluetooth/hfp/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/bluetooth/smp/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/content/activityinfo.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/content/clipdata.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/content/clipdescription.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/content/component_name.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/content/configuration.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/content/featureinfo.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/content/intent.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/content/locale.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/content/package_item_info.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/debug/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/graphics/pixelformat.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/graphics/point.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/graphics/rect.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/hardware/biometrics/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/hardware/sensor/assist/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/internal/locallog.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/internal/powerprofile.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/internal/processstats.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/media/audioattributes.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/net/network.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/net/networkcapabilities.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/net/networkrequest.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/backtrace.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/batterystats.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/batterytype.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/bundle.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/cpufreq.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/cpuinfo.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/data.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/header.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/incident.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/kernelwake.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/looper.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/message.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/messagequeue.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/metadata.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/pagetypeinfo.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/patternmatcher.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/persistablebundle.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/powermanager.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/procrank.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/ps.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/statsdata.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/system_properties.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/os/worksource.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/providers/settings.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/providers/settings/common.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/providers/settings/global.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/providers/settings/secure.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/providers/settings/system.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/activitymanagerservice.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/alarmmanagerservice.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/animationadapter.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/appwindowthumbnail.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/backup_chunks_metadata.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/face.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/fingerprint.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/forceappstandbytracker.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/intentresolver.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/jobscheduler.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/powermanagerservice.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/rolemanagerservice.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/statlogger.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/surfaceanimator.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/usagestatsservice.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/windowmanagerservice.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/windowmanagertrace.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/wirelesschargerdetector.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/connectivity/data_stall_event.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/job/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/server/location/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/service/adb.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/service/appwidget.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/service/battery.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/service/batterystats.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/service/diskstats.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/service/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/service/graphicsstats.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/service/netstats.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/service/network_watchlist.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/service/notification.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/service/package.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/service/print.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/service/procstats.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/service/procstats_enum.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/service/restricted_image.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/service/runtime.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/service/usb.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/stats/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/stats/connectivity/network_stack.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/stats/devicepolicy/device_policy.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/stats/devicepolicy/device_policy_enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/stats/dnsresolver/dns_resolver.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/stats/docsui/docsui_enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/stats/intelligence/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/stats/launcher/launcher.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/stats/location/location_enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/stats/mediametrics/mediametrics.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/stats/storage/storage_enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/stats/style/style_enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/telecomm/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/telephony/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/util/common.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/util/event_log_tags.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/util/log.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/view/display.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/view/displaycutout.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/view/displayinfo.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/view/enums.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/view/remote_animation_target.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/view/surface.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/view/surfacecontrol.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/view/windowlayoutparams.srcjar out/soong/.intermediates/frameworks/base/framework-javastream-protos/gen/frameworks/base/core/proto/android/wifi/enums.srcjar out/soong/.intermediates/frameworks/base/framework/android_common/gen/sysprop/system/apex/apexd/sysprop/ApexProperties.srcjar out/soong/.intermediates/frameworks/base/framework/android_common/gen/sysprop/system/libsysprop/srcs/android/sysprop/AdbProperties.srcjar out/soong/.intermediates/frameworks/base/framework/android_common/gen/sysprop/system/libsysprop/srcs/android/sysprop/CarProperties.srcjar out/soong/.intermediates/frameworks/base/framework/android_common/gen/sysprop/system/libsysprop/srcs/android/sysprop/ContactsProperties.srcjar out/soong/.intermediates/frameworks/base/framework/android_common/gen/sysprop/system/libsysprop/srcs/android/sysprop/CryptoProperties.srcjar out/soong/.intermediates/frameworks/base/framework/android_common/gen/sysprop/system/libsysprop/srcs/android/sysprop/DisplayProperties.srcjar out/soong/.intermediates/frameworks/base/framework/android_common/gen/sysprop/system/libsysprop/srcs/android/sysprop/SetupWizardProperties.srcjar out/soong/.intermediates/frameworks/base/framework/android_common/gen/sysprop/system/libsysprop/srcs/android/sysprop/TraceProperties.srcjar out/soong/.intermediates/frameworks/base/framework/android_common/gen/sysprop/system/libsysprop/srcs/android/sysprop/VoldProperties.srcjar out/soong/.intermediates/frameworks/base/core/res/framework-res/android_common/gen/R.jar && prebuilts/jdk/jdk9/linux-x86/bin/java -jar out/soong/host/linux-x86/framework/metalava.jar -encoding UTF-8 -source 1.8 @out/soong/.intermediates/frameworks/base/api-stubs-docs/android_common/check_last_released_api.timestamp.rsp @out/soong/.intermediates/frameworks/base/api-stubs-docs/android_common/last-apicheck/srcjars/list -bootclasspath out/soong/.intermediates/libcore/mmodules/core_platform_api/core.platform.api.stubs/android_common/javac/core.platform.api.stubs.jar:out/soong/.intermediates/libcore/core-lambda-stubs/android_common/javac/core-lambda-stubs.jar -classpath out/soong/.intermediates/frameworks/base/ext/android_common/turbine-combined/ext.jar:out/soong/.intermediates/frameworks/base/framework/android_common/turbine-jarjar/framework.jar:out/soong/.intermediates/frameworks/base/media/updatable_media_stubs/android_common/turbine-combined/updatable_media_stubs.jar:out/soong/.intermediates/frameworks/base/ext/android_common/turbine-combined/ext.jar:out/soong/.intermediates/frameworks/base/framework/android_common/turbine-jarjar/framework.jar:out/soong/.intermediates/frameworks/opt/net/voip/voip-common/android_common/turbine-combined/voip-common.jar -sourcepath "frameworks/base/core/java:frameworks/base/graphics/java:frameworks/base/location/java:frameworks/base/media/java:frameworks/base/media/mca/effect/java:frameworks/base/media/mca/filterfw/java:frameworks/base/media/mca/filterpacks/java:frameworks/base/drm/java:frameworks/base/opengl/java:frameworks/base/sax/java:frameworks/base/telecomm/java:frameworks/base/telephony/java:frameworks/base/wifi/java:frameworks/base/lowpan/java:frameworks/base/keystore/java:frameworks/base/rs/java" --no-banner --color --quiet --format=v2  --manifest frameworks/base/core/res/AndroidManifest.xml --hide-package com.android.okhttp --hide-package com.android.org.conscrypt --hide-package com.android.server --error UnhiddenSystemApi --hide RequiresPermission --hide MissingPermission --hide BroadcastBehavior --hide HiddenSuperclass --hide DeprecationMismatch --hide UnavailableSymbol --hide SdkConstant --hide HiddenTypeParameter --hide Todo --hide Typo --check-compatibility:api:released out/soong/.intermediates/prebuilts/sdk/last-released-public-api/gen/last-released-api.txt --check-compatibility:removed:released frameworks/base/api/removed.txt --merge-qualifier-annotations tools/metalava/manual --merge-qualifier-annotations libcore/ojluni/annotations/sdk  && touch out/soong/.intermediates/frameworks/base/api-stubs-docs/android_common/check_last_released_api.timestamp && rm -rf "out/soong/.intermediates/frameworks/base/api-stubs-docs/android_common/last-apicheck/srcjars") || ( echo -e "\n******************************\nYou have tried to change the API from what has been previously released in\nan SDK.  Please fix the errors listed above.\n******************************\n" ; exit 38 )
          Killed
          -e
          23:11:47 ninja failed with: exit status 1
          #### failed to build some targets (02:34:15 (hh:mm:ss)) ####
          ubuntu:/opt/a133/android$
          • tigger
            https://github.com/GloDroid/glodroid_manifest/issues/21
            https://dev.t-firefly.com/thread-104483-1-1.html
            搜了几个网页,都说编译的电脑内存不够引起, 那再重新编译一次试一试。
            • tigger
              果然内存占用有点感人
              • tigger
                这次居然成功了。
                • tigger
                  烧录试一试。
                  • tigger
                    居然启动成功了! ^_^
                    L 1 Reply Last reply Reply Quote Share 0
                    • Moved from 其它全志芯片讨论区 by  xiaowenge xiaowenge
                    • L
                      lbklbk LV 3 @tigger last edited by
                      @tigger 请问一下我的PhoenixSuit一直显示无设备连接应该怎么办?
                      tigger 1 Reply Last reply Reply Quote Share 0
                      • tigger
                        tigger LV 7 @lbklbk last edited by
                        @lbklbk
                        是自己做的板子,还是买的成品开发板?里面有没有烧程序?串口有没有输出?电脑有没有发现新usb设备?
                        • L
                          @tigger 问题解决了,非常感谢
                          • tigger
                            发现1G的 DDR跑安卓还是不太够,动不动内存警告,使用交换分区:
                            [ 1354.972377] warn_alloc: 86 callbacks suppressed
                            [ 1354.972383] dashi.benchmark: page allocation failure: order:0, mode:0x240000a(GFP_NOIO|__GFP_HIGHMEM|__GFP_MOVABLE)
                            [ 1355.001185] CPU: 1 PID: 2532 Comm: dashi.benchmark Tainted: G           O    4.9.170 #13
                            [ 1355.010298] Hardware name: sun50iw10 (DT)
                            [ 1355.014823] Call trace:
                            [ 1355.017588] [<ffffff800808c038>] dump_backtrace+0x0/0x2b8
                            [ 1355.023649] [<ffffff800808c314>] show_stack+0x24/0x30
                            [ 1355.029322] [<ffffff800847c160>] dump_stack+0x90/0xb0
                            [ 1355.035004] [<ffffff80081d3118>] warn_alloc+0x130/0x148
                            [ 1355.040882] [<ffffff80081d34f4>] __alloc_pages_nodemask+0x334/0xba8
                            [ 1355.047935] [<ffffff8008232190>] zs_malloc+0x168/0x4e8
                            [ 1355.053713] [<ffffff80085f69b0>] zram_bvec_rw.isra.22+0x410/0x880
                            [ 1355.060575] [<ffffff80085f6ea8>] zram_rw_page+0x88/0x110
                            [ 1355.066562] [<ffffff800827d58c>] bdev_write_page+0x84/0xc8
                            [ 1355.072744] [<ffffff8008217300>] __swap_writepage+0x78/0x3b0
                            [ 1355.079113] [<ffffff8008217674>] swap_writepage+0x3c/0x60
                            [ 1355.085191] [<ffffff80081e1c8c>] shrink_page_list+0x5c4/0xda0
                            [ 1355.091659] [<ffffff80081e2be0>] shrink_inactive_list+0x1a8/0x540
                            [ 1355.098522] [<ffffff80081e3784>] shrink_node_memcg+0x4b4/0x6d0
                            [ 1355.105086] [<ffffff80081e3a74>] shrink_node+0xd4/0x350
                            [ 1355.110962] [<ffffff80081e3dc8>] do_try_to_free_pages+0xd8/0x330
                            [ 1355.117729] [<ffffff80081e4120>] try_to_free_pages+0x100/0x290
                            [ 1355.124300] [<ffffff80081d370c>] __alloc_pages_nodemask+0x54c/0xba8
                            [ 1355.131355] [<ffffff800885c358>] binder_update_page_range+0x2c0/0x800
                            [ 1355.138603] [<ffffff800885d248>] binder_alloc_new_buf_locked+0x208/0x580
                            [ 1355.146147] [<ffffff800885d610>] binder_alloc_new_buf+0x50/0x78
                            [ 1355.152812] [<ffffff8008857284>] binder_transaction+0x594/0x2370
                            [ 1355.159576] [<ffffff8008859d70>] binder_thread_write+0xd10/0x1850
                            [ 1355.166432] [<ffffff800885b2d0>] binder_ioctl+0xa20/0xd58
                            [ 1355.172509] [<ffffff80082a5fdc>] compat_SyS_ioctl+0xbc/0x1d78
                            [ 1355.178984] [<ffffff8008083540>] el0_svc_naked+0x34/0x38
                            [ 1355.186067] Mem-Info:
                            [ 1355.188740] active_anon:57061 inactive_anon:57057 isolated_anon:35
                            [ 1355.188740]  active_file:10273 inactive_file:8539 isolated_file:16
                            [ 1355.188740]  unevictable:743 dirty:21 writeback:0 unstable:0
                            [ 1355.188740]  slab_reclaimable:7022 slab_unreclaimable:12955
                            [ 1355.188740]  mapped:18343 shmem:1087 pagetables:4604 bounce:0
                            [ 1355.188740]  free:3231 free_pcp:156 free_cma:26
                            [ 1355.228120] Node 0 active_anon:227160kB inactive_anon:227024kB active_file:39480kB inactive_file:34020kB unevictable:2972kB isolated(anon):140kB isolated(file):64kB mapped:73272kB dirty:84kB writeback:0kB shmem:4348kB writeback_tmp:0kB unstable:0kB pages_scanned:44 all_unreclaimable? no
                            [ 1355.256809] DMA free:4212kB min:3960kB low:7548kB high:8540kB active_anon:226332kB inactive_anon:226368kB active_file:37716kB inactive_file:34028kB unevictable:2972kB writepending:88kB present:1048576kB managed:993884kB mlocked:2972kB slab_reclaimable:27864kB slab_unreclaimable:51816kB kernel_stack:16240kB pagetables:18416kB bounce:0kB free_pcp:2264kB local_pcp:124kB free_cma:264kB
                            [ 1355.295277] lowmem_reserve[]: 0 0 0
                            [ 1355.299328] DMA: 823*4kB (UMHC) 97*8kB (UMHC) 22*16kB (MHC) 22*32kB (H) 18*64kB (H) 3*128kB (H) 3*256kB (H) 0*512kB 0*1024kB 0*2048kB 0*4096kB = 7428kB
                            [ 1355.315230] 21280 total pagecache pages
                            [ 1355.319695] 2429 pages in swap cache
                            [ 1355.323904] Swap cache stats: add 172850, delete 170430, find 20693/40184
                            [ 1355.331619] Free swap  = 606220kB
                            [ 1355.335356] Total swap = 745408kB
                            [ 1355.339184] 262144 pages RAM
                            [ 1355.342467] 0 pages HighMem/MovableOnly
                            [ 1355.346834] 13673 pages reserved
                            [ 1355.350529] 2048 pages cma reserved
                            [ 1390.266736] type=1400 audit(1648307183.535:471): avc: denied { getattr } for comm="dashi.benchmark" path="/proc/vmstat" dev="proc" ino=4026532021 scontext=u:r:untrusted_app_27:s0:c68,c256,c512,c768 tcontext=u:object_r:proc_vmstat:s0 tclass=file permissive=1 app=com.ludashi.benchmark
                            [ 1390.298115] type=1400 audit(1648307268.141:472): avc: denied { open } for comm="GC_start_routin" path="/proc/uptime" dev="proc" ino=4026531978 scontext=u:r:untrusted_app_27:s0:c512,c768 tcontext=u:object_r:proc_uptime:s0 tclass=file permissive=1 app=com.ludashi.benchmark2
                            [ 1390.326671] type=1400 audit(1648307268.141:473): avc: denied { open } for comm="GC_start_routin" path="/proc/uptime" dev="proc" ino=4026531978 scontext=u:r:untrusted_app_27:s0:c512,c768 tcontext=u:object_r:proc_uptime:s0 tclass=file permissive=1 app=com.ludashi.benchmark2 duplicate messages suppressed
                            [ 1390.364207] type=1400 audit(1648307268.141:475): avc: denied { getattr } for comm="GC_start_routin" path="/proc/uptime" dev="proc" ino=4026531978 scontext=u:r:untrusted_app_27:s0:c512,c768 tcontext=u:object_r:proc_uptime:s0 tclass=file permissive=1 app=com.ludashi.benchmark2
                            • 1 / 1
                            • First post
                              Last post
                            行为准则 | 用户协议 | 隐私权政策
