Navigation
    全志在线开发者论坛
    • Register
    • Login
    • Search
    • Categories
    • Tags
    • 在线文档
    • 社区主页
    T113 (tina) 如何编译打包spi nand flash 固件
    其它全志芯片讨论区
    5
    22
    1252
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • J
      jr_online LV 7 last edited by
      有没有大佬能指点一下!!!让我少走点弯路😖 [抱拳]
      目前的思路是在sys_config.fex 把 storage_type 改为5
      然后分区表不知道怎么改,用的是128M的spi falsh
      接着就是pack
      • Moved from D1系列-RISC-V by  YuzukiTsuru YuzukiTsuru
      • J
        分区表修改:
        打包编译固件后通过phoenixsuit下载固件到板子上
        运行起来可以看到uboot的bootlogo
        然后就运行不起来了
        报错如下:
        有没有大佬能指点一下
        • YuzukiTsuru
          柚木 鉉 LV 9 last edited by
          bootargs里修改mtd设备,或者用ubi
          在env.cfg里
          J 2 Replies Last reply Reply Quote Share 0
          • J
            jr_online LV 7 @YuzukiTsuru last edited by
            @yuzukitsuru 在 T113 (tina) 如何编译打包spi nand flash 固件 中说:
            在env.cfg里
            大佬,能说详细点吗?没弄过你说的,有点懵逼😥
            • J
              @yuzukitsuru
              大佬,请问一下怎么把文件系统改成squashfs呢?在menuconfig找不到😰
              YuzukiTsuru 1 Reply Last reply Reply Quote Share 0
              • YuzukiTsuru
                柚木 鉉 LV 9 @jr_online last edited by
                @jr_online
                Target Images --->
                [*] squashfs --->
                J 1 Reply Last reply Reply Quote Share 0
                • J
                  @jr_online
                  Target Images --->
                  [*] squashfs --->
                  可以了,谢谢大佬[抱拳]
                  L J 2 Replies Last reply Reply Quote Share 0
                  • L
                    lansecd LV 5 @jr_online last edited by
                    @jr_online 你好,我边也是Nand启动,现在遇到的问题和你一样,你这个env.cfg怎么修改的呢
                    • J
                      jr_online LV 7 @lansecd last edited by
                      @lansecd 在 T113 (tina) 如何编译打包spi nand flash 固件 中说:
                      rootfstype=squashfs
                      bootcmd=run setargs_nand boot_normal
                      L J 3 Replies Last reply Reply Quote Share 0
                      • L
                        @jr_online 这两个地方和你的一样,还是没有跑起来
                        [    2.345411] hub 2-0:1.0: USB hub found
                        [    2.349659] hub 2-0:1.0: 1 port detected
                        [    2.357934] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                        [    2.369727] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                        [    2.377228] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
                        [    2.380544] clk: Not disabling unused clocks
                        [    2.386918] cfg80211: failed to load regulatory.db
                        [    2.391717] ALSA device list:
                        [    2.400452]   #0: audiocodec
                        [    2.403812] alloc_fd: slot 0 not NULL!
                        [    2.408372] /dev/root: Can't open blockdev
                        [    2.413024] VFS: Cannot open root device "ubiblock0_5" or unknown-block(0,0): error -6
                        [    2.421929] Please append a correct "root=" boot option; here are the available partitions:
                        [    2.431306] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
                        [    2.440572] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #108
                        [    2.447397] Hardware name: Generic DT based system
                        [    2.452786] [<c010e248>] (unwind_backtrace) from [<c010a870>] (show_stack+0x10/0x14)
                        [    2.461472] [<c010a870>] (show_stack) from [<c07600a0>] (dump_stack+0x7c/0x98)
                        [    2.469573] [<c07600a0>] (dump_stack) from [<c011956c>] (panic+0x104/0x3d8)
                        [    2.477380] [<c011956c>] (panic) from [<c0b01270>] (mount_block_root+0x254/0x2fc)
                        [    2.485771] [<c0b01270>] (mount_block_root) from [<c0b014d0>] (prepare_namespace+0x138/0x178)
                        [    2.495329] [<c0b014d0>] (prepare_namespace) from [<c07745a0>] (kernel_init+0x8/0x10c)
                        [    2.504206] [<c07745a0>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
                        [    2.512688] Exception stack(0xc7825fb0 to 0xc7825ff8)
                        [    2.518348] 5fa0:                                     00000000 00000000 00000000 00000000
                        [    2.527514] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                        [    2.536680] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
                        [    2.544098] CPU1: stopping
                        [    2.547131] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.4.61 #108
                        [    2.553956] Hardware name: Generic DT based system
                        [    2.559329] [<c010e248>] (unwind_backtrace) from [<c010a870>] (show_stack+0x10/0x14)
                        [    2.568011] [<c010a870>] (show_stack) from [<c07600a0>] (dump_stack+0x7c/0x98)
                        [    2.576108] [<c07600a0>] (dump_stack) from [<c010c648>] (handle_IPI+0xcc/0x168)
                        [    2.584305] [<c010c648>] (handle_IPI) from [<c033849c>] (gic_handle_irq+0x70/0x78)
                        [    2.592793] [<c033849c>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
                        [    2.601177] Exception stack(0xc7865f80 to 0xc7865fc8)
                        [    2.606838] 5f80: 0000063c c7ecb4f4 00000000 c0114b40 00000002 c7864000 c0c04e28 c0c04e64
                        [    2.616006] 5fa0: 4000406a 410fc075 00000000 00000000 c0c627d0 c7865fd0 c0107f94 c0107f84
                        [    2.625169] 5fc0: 60000113 ffffffff
                        [    2.629080] [<c01021cc>] (__irq_svc) from [<c0107f84>] (arch_cpu_idle+0x1c/0x38)
                        [    2.637373] [<c0107f84>] (arch_cpu_idle) from [<c013de94>] (do_idle+0xd0/0x120)
                        [    2.645568] [<c013de94>] (do_idle) from [<c013e180>] (cpu_startup_entry+0x18/0x20)
                        [    2.654054] [<c013e180>] (cpu_startup_entry) from [<40102bec>] (0x40102bec)
                        [    2.661872] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
                        J 1 Reply Last reply Reply Quote Share 1
                        • J
                          那你有没有按照大佬的提议更改menuconfig
                          L 1 Reply Last reply Reply Quote Share 0
                          • L
                            @jr_online 也按大佬的来了
                            • J
                              @jr_online 也按大佬的来了
                              那有没有在sys_config.fex 把 storage_type 改为5呢?
                              • L
                                @jr_online 打开squashfs的同时,关闭ext4
                                Q 1 Reply Last reply Reply Quote Share 0
                                • Q
                                  qqqlb LV 5 @lansecd last edited by
                                  This post is deleted!
                                  • J
                                    Justyu666 LV 5 @jr_online last edited by
                                    @jr_online 在 T113 (tina) 如何编译打包spi nand flash 固件 中说:
                                    @jr_online
                                    Target Images --->
                                    [*] squashfs --->
                                    可以了,谢谢大佬[抱拳]
                                    亲,我按照帖子步骤设置了,但是打包有误,是哪里有问题呢?
                                    • J
                                      rootfstype=squashfs
                                      亲,我按照帖子步骤设置了,但是打包有错误提示,是哪里没配置正确呢?
                                      • J
                                        rootfstype=squashfs
                                        亲,我按照帖子步骤配置后打包有错误提示,是哪里没设置对呢?
                                        请大神指导一下,多谢…………!
                                        • J
                                          jr_online LV 7 @Justyu666 last edited by
                                          @justyu666 参考一下这分区表试试?
                                          ; 说明: 脚本中的字符串区分大小写,用户可以修改"="后面的数值,但是不要修改前面的字符串
                                          ;                                   固件下载参数配置
                                          ;    mbr的大小, 以Kbyte为单位
                                          [mbr]
                                          size = 252
                                          ;                                              分区配置
                                          ;  partition 定义范例:
                                          ;    [partition]                ;  //表示是一个分区
                                          ;    name        = USERFS2      ; //分区名称
                                          ;    size        = 16384        ; //分区大小 单位: 扇区.分区表示个数最多2^31 * 512 = 2T
                                          ;    downloadfile = "123.fex"   ; //下载文件的路径和名称,可以使用相对路径,相对是指相对于image.cfg文件所在分区。也可以使用绝对路径
                                          ;    keydata     = 1            ; //私有数据分区,重新量产数据将不丢失
                                          ;    encrypt     = 1            ; //采用加密方式烧录,将提供数据加密,但损失烧录速度
                                          ;    user_type   = ?            ; //私有用法
                                          ;    verify      = 1            ; //要求量产完成后校验是否正确
                                          ; 注:1、name唯一, 不允许同名
                                          ;     2、name最大12个字符
                                          ;     3、size = 0, 将创建一个无大小的空分区
                                          ;     4、align to logical block size(504 sectors), leb size = 2*(1 nand phy block size - 1 phy page size)
                                          [partition_start]
                                          [partition]
                                              name         = boot-resource
                                              size         = 7000
                                              downloadfile = "boot-resource.fex"
                                              user_type    = 0x8000
                                          [partition]
                                              name         = env
                                              size         = 504
                                              downloadfile = "env.fex"
                                              user_type    = 0x8000
                                          [partition]
                                              name         = env-redund
                                              size         = 504
                                              user_type    = 0x8000
                                          [partition]
                                              name         = boot
                                              size         = 12600
                                              downloadfile = "boot.fex"
                                              user_type    = 0x8000
                                          [partition]
                                              name         = rootfs
                                              size         = 102400
                                              downloadfile = "rootfs.fex"
                                              user_type    = 0x8000
                                          • J
                                            @jr_online 好的,谢谢
                                            • J
                                              @jr_online 亲,我按照您的分区表改后仍然无法打包,是还要改哪里呢?分区表的 mbr size 改了 252,但是打包提示还是 16384,如下图
                                              麻烦指导一下,谢谢!
                                              • J
                                                @justyu666 在 T113 (tina) 如何编译打包spi nand flash 固件 中说:
                                                麻烦指导一下,谢谢!
                                                指导算不上,我也是半吊子,你把我上面的分区表复制替换你的分区表试试,总觉得是你的name = boot-resour有问题?不应该是boot-resource咩?不知道跟这个有没有关系
                                                • 1 / 1
                                                • First post
                                                  Last post
                                                行为准则 | 用户协议 | 隐私权政策
