Navigation
    全志在线开发者论坛
    • Register
    • Login
    • Search
    • Categories
    • Tags
    • 在线文档
    • 社区主页
    T113 Tina 自带的LVGL8 G2D Test运行报错
    Linux
    1
    1
    75
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • F
      fantasya LV 2 last edited by
      使用的是芒果提供的Tina系统,lv_example下所有的包全部勾选了,然后编译运行会报错
      已经修改资源的路径,加了一些printf查看config
      下面是运行日志
      root@TinaLinux:/# lv_g2d_test 0 0 0 0
      use double buffer
      use g2d
      use g2d rotate
      use lv g2d debug
      use lv g2d fill
      use lv g2d blit
      use lv g2d blend
      use lv g2d scale
      lv_g2d_test 0 5 0 1
      one num is rotate, range is 0~3
      tow num is gif, range is 0~11, 11 is no show gif
      three num is bmp, range is 0~2, 2 is no show bmp
      four num is png, range is 0~3, 3 is no show png
      wh=800x480, vwh=800x480, bpp=32, rotated=0
      Segmentation fault
      root@TinaLinux:/# ls /mnt/UDISK/lv_g2d_test/
      root@TinaLinux:/# ls /dev/
      bus              i2c-2            mmcblk0p6        sunxi-reg
      by-name          input            mmcblk0p7        sunxi-wlan
      cedar_dev        ion              mmcblk0p8        tty
      console          kmsg             null             ttyS3
      cpu_dma_latency  mmcblk0          ptmx             ubi_ctrl
      disp             mmcblk0p1        pts              udmabuf
      fb0              mmcblk0p2        random           urandom
      full             mmcblk0p3        rfkill           usb-ffs
      g2d              mmcblk0p4        shm              zero
      gpiochip0        mmcblk0p5        snd
      int main(int argc, char *argv[]) {
      #ifdef USE_SUNXIFB_DOUBLE_BUFFER
          printf("use double buffer\n");
      #ifdef USE_SUNXIFB_G2D
          printf("use g2d\n");
      #ifdef USE_SUNXIFB_G2D_ROTATE
          printf("use g2d rotate\n");
      #ifdef LV_USE_SUNXIFB_DEBUG
          printf("use lv g2d debug\n");
      #ifdef LV_USE_SUNXIFB_G2D_FILL
          printf("use lv g2d fill\n");
      #ifdef LV_USE_SUNXIFB_G2D_BLIT
          printf("use lv g2d blit\n");
      * 列表
      #ifdef LV_USE_SUNXIFB_G2D_BLEND
          printf("use lv g2d blend\n");
      #ifdef LV_USE_SUNXIFB_G2D_SCALE
          printf("use lv g2d scale\n");
          lv_disp_drv_t disp_drv;
          lv_disp_draw_buf_t disp_buf;
          lv_indev_drv_t indev_drv;
          uint32_t rotated = LV_DISP_ROT_NONE;
          uint32_t gif_index = 5, bmp_index = 0, png_index = 1;
          char *gif_path[] = { "A:/mnt/UDISK/lv_g2d_test/240x320.gif",
                  "A:/mnt/UDISK/lv_g2d_test/313x235.gif",
                  "A:/mnt/UDISK/lv_g2d_test/320x480.gif",
                  "A:/mnt/UDISK/lv_g2d_test/409x409.gif",
                  "A:/mnt/UDISK/lv_g2d_test/658x494.gif",
                  "A:/mnt/UDISK/lv_g2d_test/800x480.gif",
                  "A:/mnt/UDISK/lv_g2d_test/800x600.gif",
                  "A:/mnt/UDISK/lv_g2d_test/800x1280.gif",
                  "A:/mnt/UDISK/lv_g2d_test/1280x720.gif",
                  "A:/mnt/UDISK/lv_g2d_test/1280x800.gif",
                  "A:/mnt/UDISK/lv_g2d_test/1920x1080.gif",
                  "A:/mnt/UDISK/lv_g2d_test/no.gif" };
          char *bmp_path[] = { "A:/mnt/UDISK/lv_g2d_test/512x352.bmp",
                  "A:/mnt/UDISK/lv_g2d_test/800x480.bmp",
                  "A:/mnt/UDISK/lv_g2d_test/no.bmp" };
          char *png_path[] = { "A:/mnt/UDISK/lv_g2d_test/47x48.png",
                  "A:/mnt/UDISK/lv_g2d_test/225x111.png",
                  "A:/mnt/UDISK/lv_g2d_test/241x148.png",
                  "A:/mnt/UDISK/lv_g2d_test/no.png"};
      • 1 / 1
      • First post
        Last post
      行为准则 | 用户协议 | 隐私权政策
