Navigation
    全志在线开发者论坛
    • Register
    • Login
    • Search
    • Categories
    • Tags
    • 在线文档
    • 社区主页
    求助,T113 tina 如何使用SPI1烧写Nand Flash?
    D1系列-RISC-V
    3
    10
    172
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • M
      msh410278586 LV 5 last edited by
      求大佬指点一下,大致需要修改哪几点?让小弟少走一点弯路。
      W 1 Reply Last reply Reply Quote Share 0
      • W
        whycan晕哥 LV 9 @msh410278586 last edited by
        @msh410278586
        从哪里取文件烧?
        用 flash_eraseall flashcp 命令行可以吗?
        M 1 Reply Last reply Reply Quote Share 0
        • M
          msh410278586 LV 5 @whycan last edited by
          @whycan 从sd卡烧写到Flash里
          WhycanService 1 Reply Last reply Reply Quote Share 0
          • WhycanService
            WhycanService LV 7 @msh410278586 last edited by
            @msh410278586 看起来是nand通讯失败了,默认使用的是spi0的,spi1需要修改uboot的sunxi-flash来支持
            M 2 Replies Last reply Reply Quote Share 0
            • M
              msh410278586 LV 5 @WhycanService last edited by
              @whycanservice 好的,谢谢,我看看这方面
              • M
                @whycanservice
                大佬,现在这算是识别SPI1上的nand flash 并烧写进去了吗?但是现在拔掉卡之后重启,串口 没有打印出来任何东西(HELLO! BOOT0 is starting 都没有打印输出),这个需要涉及到哪里的修改?求指点一下。
                [145]uart_port : 0
                [147]HELLO! BOOT0 is starting,test!
                [151]BOOT0 commit : adaf1174cc
                [154]set pll start
                [156]fix vccio detect value:0xc0
                [163]periph0 has been enabled
                [166]set pll end
                [168][pmu]: bus read error
                [170]board init ok
                [172]ZQ value = 0x30
                [174]get_pmu_exist() = -1
                [177]ddr_efuse_type: 0xa
                [179]trefi:7.8ms
                [182][AUTO DEBUG] single rank and full DQ!
                [186]ddr_efuse_type: 0xa
                [189]trefi:7.8ms
                [191][AUTO DEBUG] rank 0 row = 13
                [194][AUTO DEBUG] rank 0 bank = 8
                [198][AUTO DEBUG] rank 0 page size = 2 KB
                [202]DRAM BOOT DRIVE INFO: V0.33
                [205]DRAM CLK = 936 MHz
                [207]DRAM Type = 3 (2:DDR2,3:DDR3)
                [211]DRAMC read ODT  off.
                [213]DRAM ODT value: 0x42.
                [216]ddr_efuse_type: 0xa
                [219]DRAM SIZE =128 M
                [221]dram_tpr4:0x0
                [223]PLL_DDR_CTRL_REG:0xf8004d00
                [226]DRAM_CLK_REG:0xc0000000
                [229][TIMING DEBUG] MR2= 0x20
                [237]DRAM simple test OK.
                [239]rtc standby flag is 0x0, super standby flag is 0x0
                [245]dram size =128
                [248]card no is 0
                [249]sdcard 0 line count 4
                [252][mmc]: mmc driver ver 2021-05-21 14:47
                [261][mmc]: Wrong media type 0x0
                [264][mmc]: ***Try SD card 0***
                [281][mmc]: HSSDR52/SDR25 4 bit
                [284][mmc]: 50000000 Hz
                [286][mmc]: 15193 MB
                [288][mmc]: ***SD/MMC 0 init OK!!!***
                [384]Loading boot-pkg Succeed(index=0).
                [387]Entry_name        = u-boot
                [394]Entry_name        = optee
                [398]Entry_name        = dtb
                [401]mmc not para
                [403]Jump to second Boot.
                M/TC: OP-TEE version: e9372c9c-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #2 Sat Mar 19 11:09:45 UTC 2022 arm
                U-Boot 2018.05 (Feb 17 2023 - 08:26:51 +0000) Allwinner Technology
                [00.455]CPU:   Allwinner Family
                [00.457]Model: sun8iw20
                [00.460]optee version: major:3 minor:7
                [00.463]DRAM:  128 MiB
                [00.466]Relocation Offset is: 04ebc000
                [00.492]secure enable bit: 0
                E/TC:0   tee_read_fdt:433 fine node /firmware/optee failed with FDT_ERR_NOTFOUND
                [00.505]smc_tee_inform_fdt failed with: -65536[00.509]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
                [00.515]gic: sec monitor mode
                [00.517]flash init start
                [00.520]workmode = 17,storage type = 1
                try card 2
                set card number 2
                get card number 2
                [00.528][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
                [00.534][mmc]: Is not Boot mode!
                [00.537][mmc]: SUNXI SDMMC Controller Version:0x50310
                [00.548][mmc]: ************Try SD card 2************
                [00.553][mmc]: mmc 2 cmd timeout 100 status 100
                [00.557][mmc]: smc 2 err, cmd 8,  RTO
                [00.561][mmc]: mmc 2 close bus gating and reset
                [00.566][mmc]: mmc 2 cmd timeout 100 status 100
                [00.570][mmc]: smc 2 err, cmd 55,  RTO
                [00.573][mmc]: mmc 2 close bus gating and reset
                [00.578][mmc]: ************Try MMC card 2************
                [00.586][mmc]: mmc 2 cmd timeout 100 status 100
                [00.591][mmc]: smc 2 err, cmd 1,  RTO
                [00.594][mmc]: mmc 2 close bus gating and reset
                [00.598][mmc]: Card did not respond to voltage select!
                [00.603][mmc]: ************SD/MMC 2 init error!************
                [00.608][mmc]: mmc init product failed
                MMC init failed
                try emmc fail
                [00.615]Debug :drivers/mtd/awnand/spinand/sunxi-driver.c 504 .spi_node:12780
                [00.622]sunxi-spinand: Debug :drivers/mtd/awnand/spinand/sunxi-core.c 383
                [00.628]sunxi-spinand: AW SPINand MTD Layer Version: 1.8 20220106
                [00.634]sunxi-spinand: Debug :drivers/mtd/awnand/spinand/sunxi-core.c 402
                [00.640]sunxi-spinand: Debug :drivers/mtd/awnand/spinand/sunxi-core.c 406
                [00.647]sunxi-spinand: Debug :drivers/mtd/awnand/spinand/sunxi-core.c 409
                [00.653]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211217
                [00.661]sunxi-spinand-phy: request spi0 gpio ok
                [00.666]sunxi-spinand-phy: spi->tx_dma_chan : 1207568756!
                [00.671]sunxi-spinand-phy: spi->rx_dma_chan : 1207568784!
                [00.676]sunxi-spinand-phy: request general rx dma channel ok!
                [00.681]sunxi-spinand-phy: set spic0 clk to 20 Mhz
                [00.686]sunxi-spinand-phy: init spic0 clk ok
                sspi->base_addr = 0x4026000, the SPI control register:
                [VER] 0x4026000 = 0x00010002, [GCR] 0x4026004 = 0x00000083, [TCR] 0x4026008 = 0x00000184
                [ICR] 0x4026010 = 0x00000f00, [ISR] 0x4026014 = 0x00000032, [FCR] 0x4026018 = 0x00200020
                [FSR] 0x402601c = 0x00000000, [WCR] 0x4026020 = 0x00000000, [CCR] 0x4026024 = 0x00000002
                [SDC] 0x4026028 = 0x00002000, [BCR] 0x4026030 = 0x00000000, [TCR] 0x4026034 = 0x00000000
                [BCC] 0x4026038 = 0x00000000, [DMA] 0x4026088 = 0x000000e5
                [00.731]sunxi-spinand-phy: detect munufacture from id table: GD
                [00.737]sunxi-spinand-phy: detect spinand id: ffff51c8 ffffffff
                [00.742]sunxi-spinand-phy: ========== arch info ==========
                [00.748]sunxi-spinand-phy: Model:               GD5F1GQ5UEYIG
                [00.753]sunxi-spinand-phy: Munufacture:         GD
                [00.758]sunxi-spinand-phy: DieCntPerChip:       1
                [00.762]sunxi-spinand-phy: BlkCntPerDie:        1024
                [00.767]sunxi-spinand-phy: PageCntPerBlk:       64
                [00.771]sunxi-spinand-phy: SectCntPerPage:      4
                [00.776]sunxi-spinand-phy: OobSizePerPage:      64
                [00.780]sunxi-spinand-phy: BadBlockFlag:        0x0
                [00.785]sunxi-spinand-phy: OperationOpt:        0x7
                [00.789]sunxi-spinand-phy: MaxEraseTimes:       50000
                [00.794]sunxi-spinand-phy: EccFlag:             0x1
                [00.799]sunxi-spinand-phy: EccType:             7
                [00.803]sunxi-spinand-phy: EccProtectedType:    2
                [00.808]sunxi-spinand-phy: ========================================
                [00.813]sunxi-spinand-phy:
                [00.816]sunxi-spinand-phy: ========== physical info ==========
                [00.822]sunxi-spinand-phy: TotalSize:    128 M
                [00.826]sunxi-spinand-phy: SectorSize:   512 B
                [00.830]sunxi-spinand-phy: PageSize:     2 K
                [00.834]sunxi-spinand-phy: BlockSize:    128 K
                [00.838]sunxi-spinand-phy: OOBSize:      64 B
                [00.842]sunxi-spinand-phy: ========================================
                [00.848]sunxi-spinand-phy:
                [00.851]sunxi-spinand-phy: ========== logical info ==========
                [00.856]sunxi-spinand-phy: TotalSize:    128 M
                [00.860]sunxi-spinand-phy: SectorSize:   512 B
                [00.864]sunxi-spinand-phy: PageSize:     4 K
                [00.868]sunxi-spinand-phy: BlockSize:    256 K
                [00.873]sunxi-spinand-phy: OOBSize:      128 B
                [00.877]sunxi-spinand-phy: ========================================
                [00.883]sunxi-spinand-phy: GD5F1GQ5UEYIG reset rx bit width to 1
                [00.889]sunxi-spinand-phy: GD5F1GQ5UEYIG reset tx bit width to 1
                [00.894]sunxi-spinand-phy: set spic0 clk to 100 Mhz
                [00.899]sunxi-spinand-phy: block lock register: 0x00
                [00.904]sunxi-spinand-phy: feature register: 0x11
                [00.908]sunxi-spinand-phy: sunxi physic nand init end
                [00.913]sunxi-spinand: Debug :drivers/mtd/awnand/spinand/sunxi-core.c 414
                [00.919]sunxi-spinand: Debug :drivers/mtd/awnand/spinand/sunxi-core.c 422
                [00.926]sunxi-spinand: Debug :drivers/mtd/awnand/spinand/sunxi-core.c 427
                [00.932]sunxi-spinand: Debug :drivers/mtd/awnand/spinand/sunxi-core.c 432
                [00.939]sunxi-spinand: Debug :drivers/mtd/awnand/spinand/sunxi-core.c 443
                [00.945][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
                [00.951][mmc]: get sdc_type fail and use default host:tm1.
                [00.957][mmc]: can't find node "mmc0",will add new node
                [00.962][mmc]: fdt err returned <no error>
                [00.965][mmc]: Using default timing para
                [00.969][mmc]: SUNXI SDMMC Controller Version:0x50310
                [00.994][mmc]: card_caps:0x3000000a
                [00.997][mmc]: host_caps:0x3000003f
                [01.002]line:703 init_clocks
                [01.005]init_clocks:finish
                [01.007]drv_disp_init
                [01.014]get flash lcd idx 0
                request pwm success, pwm7:pwm7:0x2000c00.
                fdt get node offset faill: hdmi
                [01.026]HDMI 2.0 driver init start!
                [01.029]fdt_path_offset hdmi fail
                [01.032]unable to map hdmi registers
                [01.035]drv_disp_init finish
                [01.038]boot_gui_init:start
                [01.041]set disp.dev2_output_type fail. using defval=0
                [01.046]disp 0, clk: pll(364000000),clk(364000000),dclk(52000000) dsi_rate(364000000)
                     clk real:pll(360000000),clk(360000000),dclk(51428571) dsi_rate(0)
                [01.060]switch device: sel=0, type=1, mode=4, format=0, bits=0, eotf=4, cs=260
                [01.068]boot_gui_init:finish
                [01.071]Loading Environment from SUNXI_FLASH... OK
                [01.075]try to burn key
                [01.077]out of usb burn from boot: not need burn key
                sunxi work mode=0x11
                run card sprite
                [01.089]try sprite_led_gpio config
                [01.092]sprite_led_gpio start
                [01.095]sunxi sprite begin
                firmware name <NULL>
                img start = 0x81f8
                try to read mmc start 33272
                read mmc ok
                [01.111]firmware probe ok
                [01.113]fetch download map
                *************DOWNLOAD MAP DUMP************
                total download part 5
                download part[0] name          :boot-resource
                download part[0] download file :BOOT-RESOURCE_FE
                download part[0] verify file   :VBOOT-RESOURCE_F
                download part[0] lenlo         :0x1f8
                download part[0] addrlo        :0x8000
                download part[0] encrypt       :0x0
                download part[0] verify        :0x1
                download part[1] name          :env
                download part[1] download file :ENV_FEX000000000
                download part[1] verify file   :VENV_FEX00000000
                download part[1] lenlo         :0x1f8
                download part[1] addrlo        :0x81f8
                download part[1] encrypt       :0x0
                download part[1] verify        :0x1
                download part[2] name          :env-redund
                download part[2] download file :ENV_FEX000000000
                download part[2] verify file   :VENV_FEX00000000
                download part[2] lenlo         :0x1f8
                download part[2] addrlo        :0x83f0
                download part[2] encrypt       :0x0
                download part[2] verify        :0x1
                download part[3] name          :boot
                download part[3] download file :BOOT_FEX00000000
                download part[3] verify file   :VBOOT_FEX0000000
                download part[3] lenlo         :0x248c
                download part[3] addrlo        :0x85e8
                download part[3] encrypt       :0x0
                download part[3] verify        :0x1
                download part[4] name          :rootfs
                download part[4] download file :ROOTFS_FEX000000
                download part[4] verify file   :VROOTFS_FEX00000
                download part[4] lenlo         :0[01.241]LCD open finish
                x16100
                download part[4] addrlo        :0xaa74
                download part[4] encrypt       :0x0
                download part[4] verify        :0x1
                [01.254]fetch mbr
                the 0 mbr table is ok
                the 1 mbr table is ok
                the 2 mbr table is ok
                the 3 mbr table is ok
                *************MBR DUMP***************
                total mbr part 8
                part[0] classname :DISK
                part[0] user_type :32768
                part[0] keydata   :0
                part[0] ro        :0
                part[1] name      :env
                part[1] classname :DISK
                part[1] user_type :32768
                part[1] keydata   :0
                part[1] ro        :0
                part[2] classname :DISK
                part[2] user_type :32768
                part[2] keydata   :0
                part[2] ro        :0
                part[3] name      :boot
                part[3] classname :DISK
                part[3] user_type :32768
                part[3] keydata   :0
                part[3] ro        :0
                part[4] classname :DISK
                part[4] lenlo     :0x16100
                part[4] user_type :32768
                part[4] keydata   :0
                part[4] ro        :0
                part[5] name      :private
                part[5] classname :DISK
                part[5] addrlo    :0x20b74
                part[5] lenlo     :0x2800
                part[5] user_type :32768
                part[5] keydata   :0
                part[5] ro        :0
                part[6] name      :rootfs_data
                part[6] classname :DISK
                part[6] addrlo    :0x23374
                part[6] lenlo     :0xb220
                part[6] user_type :32768
                part[6] keydata   :0
                part[6] ro        :0
                part[7] name      :UDISK
                part[7] classname :DISK
                part[7] addrlo    :0x2e594
                part[7] lenlo     :0x0
                part[7] user_type :33024
                part[7] keydata   :0
                part[7] ro        :0
                total mbr part 8
                part[0] user_type :0x8000
                part[0] keydata   :0x0
                part[0] ro        :0x0
                part[1] name      :env
                part[1] user_type :0x8000
                part[1] keydata   :0x0
                part[1] ro        :0x0
                part[2] user_type :0x8000
                part[2] keydata   :0x0
                part[2] ro        :0x0
                part[3] name      :boot
                part[3] user_type :0x8000
                part[3] keydata   :0x0
                part[3] ro        :0x0
                part[4] user_type :0x8000
                part[4] keydata   :0x0
                part[4] ro        :0x0
                part[5] user_type :0x8000
                part[5] keydata   :0x0
                part[5] ro        :0x0
                part[6] user_type :0x8000
                part[6] keydata   :0x0
                part[6] ro        :0x0
                part[7] name      :UDISK
                part[7] lenlo     :0x0
                part[7] user_type :0x8100
                part[7] keydata   :0x0
                part[7] ro        :0x0
                [01.530]begin to erase flash
                total part: 9
                mbr 0, 8000, 8000
                boot-resource 1, 1f8, 8000
                env 2, 1f8, 8000
                env-redund 3, 1f8, 8000
                boot 4, 248c, 8000
                rootfs 5, 16100, 8000
                private 6, 2800, 8000
                rootfs_data 7, b220, 8000
                UDISK 8, 0, 8100
                [01.552]erase blk 0 to blk 32
                need erase flash: 1
                [01.625]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
                device nand0 <nand>, # parts = 4
                 #: name		size		offset		mask_flags
                 0: boot0               0x00100000	0x00000000	1
                 1: uboot               0x00300000	0x00100000	1
                 2: secure_storage      0x00100000	0x00400000	1
                 3: sys                 0x07b00000	0x00500000	0
                active partition: nand0,0 - (boot0) 0x00100000 @ 0x00000000
                defaults:
                mtdids  : nand0=nand
                [01.675]CONFIG_AW_MTD_SPINAND
                [01.678]MTD info (4)
                [01.680]pagesize: 0x1000
                [01.682]blksize: 0x40000
                [01.684]num  offset     bytes      name
                [01.688]0    0x00000000 0x00100000 boot0
                [01.691]1    0x00100000 0x00300000 uboot
                [01.695]2    0x00400000 0x00100000 secure_storage
                [01.699]3    0x00500000 0x07b00000 sys
                [01.703]ubi attach the last part of mtd device: NO.3
                [01.770]ubi0: attaching mtd4
                [01.991]ubi0: scanning is finished
                [02.000]ubi0: attached mtd4 (name "sys", size 123 MiB)
                [02.004]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
                [02.011]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
                [02.017]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
                [02.023]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
                [02.029]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
                [02.035]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
                [02.043]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
                private part exist
                [02.060]logical area info: 468 258048 last_lba: 235871
                [02.065]CONFIG_AW_MTD_SPINAND
                [02.068]MTD info (4)
                [02.070]pagesize: 0x1000
                [02.072]blksize: 0x40000
                [02.074]num  offset     bytes      name
                [02.078]0    0x00000000 0x00100000 boot0
                [02.081]1    0x00100000 0x00300000 uboot
                [02.085]2    0x00400000 0x00100000 secure_storage
                [02.090]3    0x00500000 0x07b00000 sys
                [02.093]MBR info (unalign):
                [02.096]partno   addr       sects      type       name
                [02.100]0        0x00000000 0x00008000 0x00000001 mbr
                [02.105]1        0x00008000 0x000001f8 0x00008000 boot-resource
                [02.111]2        0x000081f8 0x000001f8 0x00008000 env
                [02.116]3        0x000083f0 0x000001f8 0x00008000 env-redund
                [02.121]4        0x000085e8 0x0000248c 0x00008000 boot
                [02.126]5        0x0000aa74 0x00016100 0x00008000 rootfs
                [02.131]6        0x00020b74 0x00002800 0x00008000 private
                [02.136]7        0x00023374 0x0000b220 0x00008000 rootfs_data
                [02.141]8        0x0002e594 0x0000ad40 0x00008100 UDISK
                [02.146]ubi attach the last part of mtd device: NO.3
                [02.151]MBR info (align):
                [02.153]partno   addr       sects      type       name
                [02.158]0        0x00002800 0x000081f0 0x00000001 mbr
                [02.163]1        0x0000a9f0 0x000001f8 0x00008000 boot-resource
                [02.169]2        0x0000abe8 0x000001f8 0x00008000 env
                [02.173]3        0x0000ade0 0x000001f8 0x00008000 env-redund
                [02.179]4        0x0000afd8 0x00002568 0x00008000 boot
                [02.184]5        0x0000d540 0x00016260 0x00008000 rootfs
                [02.189]6        0x000237a0 0x00002958 0x00008000 private
                [02.194]7        0x000260f8 0x0000b328 0x00008000 rootfs_data
                [02.199]8        0x00031420 0x0000ad40 0x00008100 UDISK
                GPT:boot-resource: 8000          81f7
                GPT:env         : 81f8          83ef
                GPT:env-redund  : 83f0          85e7
                GPT:boot        : 85e8          aa73
                GPT:rootfs      : aa74          20b73
                GPT:private     : 20b74         23373
                GPT:rootfs_data : 23374         2e593
                GPT:UDISK       : 2e594         392d3
                begin to store data
                part 0 name boot-resource
                keydata = 0x0
                part 1 name env
                keydata = 0x0
                part 2 name env-redund
                keydata = 0x0
                part 3 name boot
                keydata = 0x0
                part 4 name rootfs
                keydata = 0x0
                part 5 name private
                keydata = 0x0
                find keypart private
                keypart read start: 0x20b74, sectors 0x2800
                keypart part private read  0x20b74, sectors 0x2800
                part 6 name rootfs_data
                keydata = 0x0
                part 7 name UDISK
                keydata = 0x0
                begin to erase
                [02.281]erase blk 0 to blk 32
                [02.350]erase blk 40 to blk 1024
                finish erase
                rewrite
                force mbr
                defaults:
                mtdids  : nand0=nand
                [04.432]CONFIG_AW_MTD_SPINAND
                [04.435]MTD info (4)
                [04.437]pagesize: 0x1000
                [04.439]blksize: 0x40000
                [04.441]num  offset     bytes      name
                [04.445]0    0x00000000 0x00100000 boot0
                [04.449]1    0x00100000 0x00300000 uboot
                [04.452]2    0x00400000 0x00100000 secure_storage
                [04.457]3    0x00500000 0x07b00000 sys
                [04.460]MBR info (unalign):
                [04.463]partno   addr       sects      type       name
                [04.467]0        0x00000000 0x00008000 0x00000001 mbr
                [04.472]1        0x00008000 0x000001f8 0x00008000 boot-resource
                [04.478]2        0x000081f8 0x000001f8 0x00008000 env
                [04.483]3        0x000083f0 0x000001f8 0x00008000 env-redund
                [04.488]4        0x000085e8 0x0000248c 0x00008000 boot
                [04.493]5        0x0000aa74 0x00016100 0x00008000 rootfs
                [04.498]6        0x00020b74 0x00002800 0x00008000 private
                [04.503]7        0x00023374 0x0000b220 0x00008000 rootfs_data
                [04.508]8        0x0002e594 0x00000000 0x00008100 UDISK
                [04.513]ubi attach the last part of mtd device: NO.3
                [04.518]MBR info (align):
                [04.520]partno   addr       sects      type       name
                [04.525]0        0x00002800 0x000081f0 0x00000001 mbr
                [04.530]1        0x0000a9f0 0x000001f8 0x00008000 boot-resource
                [04.536]2        0x0000abe8 0x000001f8 0x00008000 env
                [04.540]3        0x0000ade0 0x000001f8 0x00008000 env-redund
                [04.546]4        0x0000afd8 0x00002568 0x00008000 boot
                [04.551]5        0x0000d540 0x00016260 0x00008000 rootfs
                [04.556]6        0x000237a0 0x00002958 0x00008000 private
                [04.561]7        0x000260f8 0x0000b328 0x00008000 rootfs_data
                [04.566]8        0x00031420 0x00000000 0x00008100 UDISK
                [04.571]ubi attach the last part of mtd device: NO.3
                [04.576]ubi attatch mtd, name: sys
                [04.579]ubi0: detaching mtd4
                [04.582]ubi0: mtd4 is detached
                [04.585]ubi0: attaching mtd4
                [04.696]ubi0: scanning is finished
                [04.699]ubi0: empty MTD device detected
                [04.727]ubi0: attached mtd4 (name "sys", size 123 MiB)
                [04.732]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
                [04.738]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
                [04.744]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
                [04.751]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
                [04.756]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
                [04.763]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
                [04.770]ubi0: available PEBs: 468, total reserved PEBs: 24, PEBs reserved for bad PEB handling: 20
                Creating static volume mbr of size 17031168
                Creating dynamic volume boot-resource of size 258048
                Creating dynamic volume env of size 258048
                Creating dynamic volume env-redund of size 258048
                Creating dynamic volume boot of size 4902912
                Creating dynamic volume rootfs of size 46448640
                Creating dynamic volume private of size 5419008
                Creating dynamic volume rootfs_data of size 23482368
                No size specified -> Using max size (22708224)
                [07.321]reset last volume size to 0xad40
                Creating dynamic volume UDISK of size 22708224
                [07.377]fill gap start: volume mbr sects 0x7f80
                [11.545]fill gap end: volume mbr
                [11.548]update partition map
                [11.562]logical area info: 468 258048 last_lba: 235871
                keypart write start: 0x20b74, sectors 0x2800
                flash exit
                [11.658]successed in erasing flash
                force mbr
                defaults:
                mtdids  : nand0=nand
                [11.703]CONFIG_AW_MTD_SPINAND
                [11.705]MTD info (4)
                [11.707]pagesize: 0x1000
                [11.710]blksize: 0x40000
                [11.712]num  offset     bytes      name
                [11.715]0    0x00000000 0x00100000 boot0
                [11.719]1    0x00100000 0x00300000 uboot
                [11.723]2    0x00400000 0x00100000 secure_storage
                [11.727]3    0x00500000 0x07b00000 sys
                [11.731]MBR info (unalign):
                [11.733]partno   addr       sects      type       name
                [11.738]0        0x00000000 0x00008000 0x00000001 mbr
                [11.743]1        0x00008000 0x000001f8 0x00008000 boot-resource
                [11.748]2        0x000081f8 0x000001f8 0x00008000 env
                [11.753]3        0x000083f0 0x000001f8 0x00008000 env-redund
                [11.758]4        0x000085e8 0x0000248c 0x00008000 boot
                [11.763]5        0x0000aa74 0x00016100 0x00008000 rootfs
                [11.768]6        0x00020b74 0x00002800 0x00008000 private
                [11.773]7        0x00023374 0x0000b220 0x00008000 rootfs_data
                [11.779]8        0x0002e594 0x0000ad40 0x00008100 UDISK
                [11.784]ubi attach the last part of mtd device: NO.3
                [11.789]MBR info (align):
                [11.791]partno   addr       sects      type       name
                [11.796]0        0x00002800 0x000081f0 0x00000001 mbr
                [11.800]1        0x0000a9f0 0x000001f8 0x00008000 boot-resource
                [11.806]2        0x0000abe8 0x000001f8 0x00008000 env
                [11.811]3        0x0000ade0 0x000001f8 0x00008000 env-redund
                [11.816]4        0x0000afd8 0x00002568 0x00008000 boot
                [11.821]5        0x0000d540 0x00016260 0x00008000 rootfs
                [11.826]6        0x000237a0 0x00002958 0x00008000 private
                [11.831]7        0x000260f8 0x0000b328 0x00008000 rootfs_data
                [11.837]8        0x00031420 0x0000ad40 0x00008100 UDISK
                [11.842]ubi attach the last part of mtd device: NO.3
                [11.846]ubi attatch mtd, name: sys
                [11.850]ubi0: detaching mtd4
                [11.852]ubi0: mtd4 is detached
                [11.855]ubi0: attaching mtd4
                [12.076]ubi0: scanning is finished
                [12.085]ubi0: attached mtd4 (name "sys", size 123 MiB)
                [12.090]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
                [12.096]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
                [12.102]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
                [12.109]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
                [12.114]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
                [12.121]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
                [12.128]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
                [12.137]volume mbr existed, not create again
                [12.141]volume boot-resource existed, not create again
                [12.146]volume env existed, not create again
                [12.150]volume env-redund existed, not create again
                [12.154]volume boot existed, not create again
                [12.158]volume rootfs existed, not create again
                [12.163]volume private existed, not create again
                [12.167]volume rootfs_data existed, not create again
                [12.172]volume UDISK existed, not create again
                [12.512]fill gap start: volume mbr sects 0x7f80
                [16.679]fill gap end: volume mbr
                [16.682]update partition map
                [16.688]begin to download part
                [16.691]begin to download part boot-resource
                partdata hi 0x0
                partdata lo 0x14000
                sparse: bad magic
                [16.730]successed in writting part boot-resource
                [16.736]fill gap start: volume boot-resource sects 0x158
                [16.838]fill gap end: volume boot-resource
                origin_verify value = e6f75b5c, active_verify value = e6f75b5c
                [16.857]successed in verify part boot-resource
                [16.861]successed in download part boot-resource
                [16.865]begin to download part env
                partdata hi 0x0
                partdata lo 0x20000
                sparse: bad magic
                [16.906]successed in writting part env
                [16.911]fill gap start: volume env sects 0xf8
                [17.012]fill gap end: volume env
                origin_verify value = 46811025, active_verify value = 46811025
                [17.035]successed in verify part env
                [17.038]successed in download part env
                [17.042]begin to download part env-redund
                partdata hi 0x0
                partdata lo 0x20000
                sparse: bad magic
                [17.083]successed in writting part env-redund
                [17.089]fill gap start: volume env-redund sects 0xf8
                [17.190]fill gap end: volume env-redund
                [17.214]successed in verify part env-redund
                [17.218]successed in download part env-redund
                [17.222]begin to download part boot
                partdata hi 0x0
                partdata lo 0x43f800
                sparse: bad magic
                [18.675]successed in writting part boot
                [18.681]fill gap start: volume boot sects 0x290
                [18.783]fill gap end: volume boot
                origin_verify value = 78c1cc8, active_verify value = 78c1cc8
                [19.278]successed in verify part boot
                [19.281]successed in download part boot
                [19.285]begin to download part rootfs
                partdata hi 0x0
                partdata lo 0xfa0000
                sparse: bad magic
                [24.572]successed in writting part rootfs
                [24.578]fill gap start: volume rootfs sects 0xe400
                [24.880]fill gap end: volume rootfs
                origin_verify value = a9185c30, active_verify value = a9185c30
                [26.678]successed in verify part rootfs
                [26.681]successed in download part rootfs
                [26.686]successed in downloading part
                uboot size = 0x150000
                storage type = 0
                [26.752]uboot blk range [8-32)
                [26.755]download uboot to block 8 (11 blocks) len 1344K
                [27.162]download uboot to block 19 (11 blocks) len 1344K
                sunxi_sprite_deal_uboot ok
                [27.573]successed in downloading uboot
                [27.581]spinand_mtd_get_flash_info get spi-nand node from fdt
                dram para[0] = 3a8
                dram para[1] = 3
                dram para[2] = 7b7bfb
                dram para[3] = 0
                dram para[4] = 10d2
                dram para[5] = 800000
                dram para[6] = 1e14
                dram para[7] = 42
                dram para[8] = 20
                dram para[9] = 0
                dram para[10] = 4899d7
                dram para[11] = 1c241d0
                dram para[12] = a4073
                dram para[13] = b4787896
                dram para[14] = 0
                dram para[15] = 48484848
                dram para[16] = 48
                dram para[17] = 1620121e
                dram para[18] = 0
                dram para[19] = 0
                dram para[20] = 0
                dram para[21] = 340000
                dram para[22] = 46
                dram para[23] = b4006103
                dram para[24] = 0
                dram para[25] = 0
                dram para[26] = 0
                dram para[27] = 0
                dram para[28] = 0
                dram para[29] = 0
                dram para[30] = 0
                dram para[31] = 0
                storage type = 0
                [27.646]download boot0 to block 0 len 48K
                [27.665]download boot0 to block 1 len 48K
                [27.684]download boot0 to block 2 len 48K
                [27.704]download boot0 to block 3 len 48K
                [27.723]download boot0 to block 4 len 48K
                [27.742]download boot0 to block 5 len 48K
                [27.761]download boot0 to block 6 len 48K
                [27.780]download boot0 to block 7 len 48K
                [27.800]successed in downloading boot0
                CARD OK
                [27.804]sprite success
                sprite_next_work=3
                next work 3
                SUNXI_UPDATE_NEXT_ACTION_SHUTDOWN
                [30.812][mmc]: mmc exit start
                [30.825][mmc]: mmc 2 cmd timeout 100 status 100
                [30.829][mmc]: smc 2 err, cmd 1,  RTO
                [30.832][mmc]: mmc 2 close bus gating and reset
                [30.837][mmc]: mmc card did not respond to voltage select!
                [30.842][mmc]: mmc 2 exit failed
                • W
                  whycan晕哥 LV 9 @msh410278586 last edited by whycan
                  据我所知,SPI1 不能启动吧?
                  • M
                    @whycan 😥 大佬能麻烦确认一下吗?确定的话,我就不瞎琢磨了
                    • W
                      @msh410278586
                      不完全确定,如果SPI1能boot,那么应该会写上.
                      手册: T113-S3_User_Manual_V1.1.pdf
                      • M
                        @whycan 好的,谢谢大佬!
                        • 1 / 1
                        • First post
                          Last post
                        行为准则 | 用户协议 | 隐私权政策
