Navigation
    全志在线开发者论坛
    • Register
    • Login
    • Search
    • Categories
    • Tags
    • 在线文档
    • 社区主页
    v831刚上电没有log打印,到了kernel阶段才有
    编译和烧写问题专区
    2
    5
    49
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • C
      cruise33 LV 5 last edited by
      正常来说,板子刚上电会类似有如下的打印:
      但因为硬件没用到uart0,改成uart1后,到了kernel起来阶段,才有打印,而且烧录时也没有打印。请问这块的打印是在哪里控制?
      查了些历史帖,都在讨论env.cfg、sys_config.fex、dts等
      env.cfg部分内容如下
      #kernel command arguments
      earlyprintk=sunxi-uart,0x05000000
      initcall_debug=0
      console=ttyS1,115200
      nand_root=/dev/ubiblock0_4
      mmc_root=/dev/mmcblk0p4
      nor_root=/dev/mtdblock2
      init=/init
      rdinit=/rdinit
      loglevel=8
      cma=4M
      coherent_pool=16K
      sys_config.fex如下:
      [uart_para]
      uart_debug_port = 1
      uart_debug_tx   = port:PG06<5><1><default><default>
      uart_debug_rx   = port:PG07<5><1><default><default>
      ;uart configuration
      ;uart_type ---  2 (2 wire), 4 (4 wire), 8 (8 wire, full function)
      [uart1]
      uart1_used       = 1
      uart1_port       = 1
      uart1_type       = 2
      uart1_tx         = port:PG06<5><1><default><default>
      uart1_rx         = port:PG07<5><1><default><default>
      dts我直接改了sun8iw19p1-pinctrl.dsti:
      			uart1_pins_a: uart1@0 {
      				allwinner,pins = "PG6", "PG7";
      				allwinner,pname = "uart1_tx", "uart1_rx";
      				allwinner,function = "uart1";
      				allwinner,muxsel = <5>;
      				allwinner,drive = <1>;
      				allwinner,pull = <1>;
      			uart1_pins_b: uart1@1 {
      				allwinner,function = "io_disabled";
      				allwinner,muxsel = <7>;
      				allwinner,pull = <0>;
      原理图:
      还有哪里没改对?
      • WhycanService
        WhycanService LV 7 last edited by WhycanService
        kernel要指定log的寄存器地址
        make kernel_menuconfig 找到 Kernel low-level debugging functions,修改寄存器地址
        C 1 Reply Last reply Reply Quote Share 0
        • C
          cruise33 LV 5 @WhycanService last edited by
          @whycanservice kernel加载阶段串口是有打印的,但板子刚上电时没有打印,也没有bootdelay的等待。“kernel指定log寄存器地址” 跟这个没关系吧?我也试了,没啥变化, debugging port也试过选成uart1,也没作用
          WhycanService 1 Reply Last reply Reply Quote Share 0
          • WhycanService
            WhycanService LV 7 @cruise33 last edited by
            @cruise33 uboot也需要修改,修改uart index
            • C
              @whycanservice 在 v831刚上电没有log打印,到了kernel阶段才有 中说:
              参考了这个精华帖
              https://bbs.aw-ol.com/topic/1673/全志芯片tina-linux-修改-uart-引脚-uart端口?_=1679296875490
              env.cfg
              earlyprintk=sunxi-uart,0x05000400
              initcall_debug=0
              board.dts
              (为啥用&uart1这个标签会编译不过😑 )
              soc@03000000 {
              		uart@05000000 {
              			pinctrl-names = "default", "sleep";
              			pinctrl-0 = <&uart0_pins_a>;
              			pinctrl-1 = <&uart0_pins_b>;
              			status = "disabled";
              		/*&uart1*/
              		uart@05000400 {
              			pinctrl-0 = <&uart1_pins_a>;
              			pinctrl-1 = <&uart1_pins_b>;
              			uart1_type = <2>;
              			status = "okay";
              		pinctrl@0300b000 {
              				allwinner,function = "gpio_in";
              sun8iw19p1_nor_defconfig
              CONFIG_SPECIFY_CONSOLE_INDEX=y
              CONFIG_CONS_INDEX=2
              还是只有如下开始的log🤒 :
              BOOT0的打印 和烧录时的打印到底受哪里控制..
              • 1 / 1
              • First post
                Last post
              行为准则 | 用户协议 | 隐私权政策
