Navigation
    全志在线开发者论坛
    • Register
    • Login
    • Search
    • Categories
    • Tags
    • 在线文档
    • 社区主页
    使用自带codec录音报错, arecord: pcm_read:2072: read error: I/O error
    D1系列-RISC-V
    2
    5
    40
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • R
      RTQQQ LV 4 last edited by
      使用自带的codec进行录音,报错了,这是什么原因呢?alsamixer也设置了
      root@TinaLinux:/# arecord -D hw:0,0 -f S16_LE test.wav
      Recording WAVE 'test.wav' : [  162.476954] [SNDCODEC][sunxi_card_hw_params][620]:stream_flag: 1
      Signed 16 bit Little Endian, Rate 8000 Hz, Mono
      • WhycanService
        WhycanService LV 7 last edited by
        通过 amixer 查看 route 状态,确认是否设置了需要的上下电通路。
        R 2 Replies Last reply Reply Quote Share 0
        • R
          RTQQQ LV 4 @WhycanService last edited by
          @whycanservice
          你好,这是amixer 的显示内容,请问如何操作呢?
          root@TinaLinux:/# amixer
          Simple mixer control 'Headphone',0
            Capabilities: pswitch pswitch-joined
            Playback channels: Mono
            Mono: Playback [on]
          Simple mixer control 'Headphone volume',0
            Capabilities: volume volume-joined
            Capture channels: Mono
            Limits: 0 - 7
            Mono: 4 [57%]
          Simple mixer control 'FMINL gain volume',0
            Mono: Playback [off]
          Simple mixer control 'FMINR gain volume',0
          Simple mixer control 'ADC1 ADC2 swap',0
            Capabilities: enum
            Items: 'Off' 'On'
            Item0: 'Off'
          Simple mixer control 'ADC1 Input FMINL',0
          Simple mixer control 'ADC1 Input LINEINL',0
          Simple mixer control 'ADC1 Input MIC1 Boost',0
          Simple mixer control 'ADC1 volume',0
            Limits: 0 - 255
            Mono: 160 [63%]
          Simple mixer control 'ADC2 Input FMINR',0
          Simple mixer control 'ADC2 Input LINEINR',0
          Simple mixer control 'ADC2 Input MIC2 Boost',0
          Simple mixer control 'ADC2 volume',0
            Limits: 0 - 255
            Mono: 160 [63%]
          Simple mixer control 'ADC3 ADC4 swap',0
            Capabilities: enum
            Items: 'Off' 'On'
            Item0: 'Off'
          Simple mixer control 'ADC3 Input MIC3 Boost',0
          Simple mixer control 'ADC3 volume',0
            Limits: 0 - 255
            Mono: 160 [63%]
          Simple mixer control 'DAC volume',0
            Playback channels: Front Left - Front Right
            Capture channels: Front Left - Front Right
            Limits: 0 - 255
            Front Left: 160 [63%]
            Front Right: 160 [63%]
          Simple mixer control 'HpSpeaker',0
          Simple mixer control 'LINEINL gain volume',0
          Simple mixer control 'LINEINR gain volume',0
          Simple mixer control 'LINEOUT',0
          Simple mixer control 'LINEOUT volume',0
            Limits: 0 - 31
            Mono: 26 [84%]
          Simple mixer control 'LINEOUTL Output Select',0
            Capabilities: enum
            Items: 'DAC_SINGLE' 'DAC_DIFFER'
            Item0: 'DAC_DIFFER'
          Simple mixer control 'LINEOUTR Output Select',0
            Capabilities: enum
            Item0: 'DAC_DIFFER'
          Simple mixer control 'MIC1 Input Select',0
            Capabilities: enum
            Items: 'MIC_DIFFER' 'MIC_SINGLE'
            Item0: 'MIC_DIFFER'
          Simple mixer control 'MIC1 gain volume',0
            Limits: 0 - 31
            Mono: 31 [100%]
          Simple mixer control 'MIC2 Input Select',0
            Capabilities: enum
            Item0: 'MIC_DIFFER'
          Simple mixer control 'MIC2 gain volume',0
            Limits: 0 - 31
            Mono: 31 [100%]
          Simple mixer control 'MIC3 Input Select',0
            Capabilities: enum
            Item0: 'MIC_DIFFER'
          Simple mixer control 'MIC3 gain volume',0
            Limits: 0 - 31
            Mono: 31 [100%]
          Simple mixer control 'codec hub mode',0
            Capabilities: enum
            Items: 'hub_disable' 'hub_enable'
            Item0: 'hub_disable'
          Simple mixer control 'digital volume',0
            Limits: 0 - 63
            Mono: 63 [100%]
          • R
            • WhycanService
              amixer -D hw:audiocodec cset numid=21 0 && \
                  amixer -D hw:audiocodec cset numid=9 30 && \
                  amixer -D hw:audiocodec cset numid=23 1 && \
                  amixer -D hw:audiocodec cset numid=25 0 && \
                  arecord -D hw:audiocodec -f S16_LE -t wav -r 16000 -d 3 t.wav
              • 1 / 1
              • First post
                Last post
              行为准则 | 用户协议 | 隐私权政策
