楼主 #1 2018-05-14 17:53:46
已发帖子: 9,250
发现一个不错的小米手环 Android项目
https://github.com/betomaluje/Mi-Band
Sweet和简单的Android实施来控制小米Mi Band的某些方面。
  • 连接和断开
  • 开始振动(预定义和海关值)
  • 更改LED的颜色(具有预定义和海关值)
  • 获取电池信息
  • 与您的Mi Band同步(步骤,睡眠时间等)
  • 实时步进计数器
楼主 #2 2018-05-15 14:40:12
已发帖子: 9,250
Re: 发现一个不错的小米手环 Android项目
占坑
楼主 #3 2018-05-15 14:40:14
已发帖子: 9,250
占坑
楼主 #4 2018-05-15 14:42:39
已发帖子: 9,250
经过一番折腾,终于把环境搭起来了,试一试看能否编译。
楼主 #5 2018-05-15 15:11:13
已发帖子: 9,250
Unsupported method: BaseConfig.getApplicationIdSuffix().
The version of Gradle you connect to does not support that method.
To resolve the problem you can change/upgrade the target version of Gradle you connect to.
Alternatively, you can ignore this exception and read other information from the model.
还是出现了错误.
楼主 #6 2018-05-15 15:15:32
已发帖子: 9,250
https://stackoverflow.com/questions/44546849/unsupported-method-baseconfig-getapplicationidsuffix
build.gradle:
classpath 'com.android.tools.build:gradle:1.2.3'
改为 ==>
classpath 'com.android.tools.build:gradle:2.2.1'
楼主 #7 2018-05-15 15:37:43
已发帖子: 9,250
sync failed    14s 834ms
Minimum supported Gradle version is 2.14.1. Current version is 2.2.1.
Please fix the project's Gradle settings.
Fix Gradle wrapper and re-import project
Gradle settings
失败真是无处不在.
楼主 #8 2018-05-15 18:12:14
已发帖子: 9,250
build.gradle 改成这样:
buildscript {
    repositories {
        jcenter()
        //google()
        maven {
            url 'https://maven.google.com'
    dependencies {
        classpath 'com.android.tools.build:gradle:3.0.0'
        // NOTE: Do not place your application dependencies here; they belong
        // in the individual module build.gradle files
可以通过编译,生成了apk文件, 不知道为何,手机插上了,adb 设备也有了,但是 android studio 无法调试, adb shell命令也无法连接。
楼主 #9 2018-05-15 18:22:25
已发帖子: 9,250
Note: this is thanks to the new Android Studio that uses jCenter instead of MavenCentral. To see this, you can open your main build.gradle file, and under the repositories you should see jcenter(). If not, add this as a repository
   allprojects {
       repositories {
            mavenCentral()
            maven {
                url 'https://dl.bintray.com/betomaluje/maven/'
作者貌似有提醒了?
楼主 #10 2018-05-15 18:26:38
已发帖子: 9,250
没有扫描的按钮, 点 connect 也死活无法反应.
难道要手动设置蓝牙地址?
赶紧找代码
楼主 #11 2018-05-15 18:27:44
已发帖子: 9,250
楼主 #12 2018-05-16 14:55:48
已发帖子: 9,250
14:51:57 Gradle sync started
14:52:24 Gradle sync completed
14:52:24 Executing tasks: [:app:generateDebugSources, :app:generateDebugAndroidTestSources, :app:mockableAndroidJar, :app:prepareDebugUnitTestDependencies]
14:52:33 Gradle build finished in 9s 346ms
14:54:09 Executing tasks: [:app:generateDebugSources, :app:generateDebugAndroidTestSources, :app:mockableAndroidJar, :app:prepareDebugUnitTestDependencies, :app:compileDebugSources, :app:compileDebugAndroidTestSources, :app:compileDebugUnitTestSources]
14:54:19 Gradle build finished in 9s 879ms
14:54:25 Executing tasks: [:app:assembleDebug]
14:54:32 Gradle build finished in 7s 105ms
14:54:32 Build APK
         APK(s) generated successfully.
         Show in Explorer
换了一台电脑,折腾很久,可以编译,
but, 并没有以生成 apk 文件, 小白入坑真难.
楼主 #13 2018-05-17 09:14:36
已发帖子: 9,250
入坑小白终于找到套路,
用Android Studio 新建一个项目,这个项目编译和生成apk 都是正常的,
你把这个项目的 两个 build.gradle, 一个 gradle-wrapper.properties 均复制到 MiBand项目下对应位置即可。
楼主 #14 2018-05-17 10:22:13
已发帖子: 9,250
MiBand那个只是一个Service,所以桌面没有图标,我还以为能单独运行,害我浪费一个小时。
估计MiBand和MiBandExample是搭配用的, MiBandExample调用MiBand里面的Service.
楼主 #15 2018-05-17 10:22:29
已发帖子: 9,250
最后还是没能跑起来.....
楼主 #16 2018-05-17 20:28:48
已发帖子: 9,250
也并不是一无所获,终于学会了在线调试Android程序,其实以前就会了,很久不用又忘记了, 捂脸.
#17 2020-04-10 10:01:05
hzqlz
已发帖子: 148
好帖,有空也玩玩
#18 2020-05-12 11:27:33
hanhua
好帖,mark一下,有空再弄
