楼主 #1 2020-04-02 23:02:54
迪卡
所在地: 河北
已发帖子: 916
F1C100S使用主线uboot如何更改默认终端串口
默认是UART0 PE0 PE1
想改到到UART1 PA2 PA3
我看了坑网的zero改串口,别人问这个问题的时候,晕哥也是让看zero的,
但是我改了设备树里的pinctr复用,chose,各种东西。
但是spl还是uart0打印,而uart1里没有任何数据。
无从下手,改了好多遍
#2 2020-04-03 09:35:12
zzm24
已发帖子: 113
Re: F1C100S使用主线uboot如何更改默认终端串口
suniv.dtsi
line124
            uart0_pins_a: uart-pins-pe {
                pins = "PE0", "PE1";
                function = "uart0";
            uart1_pins_a: uart-pins-pa {
                pins = "PA2", "PA3";
                function = "uart1";
u-boot\arch\arm\mach-sunxi\board.c
line86
#elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUNIV)
    sunxi_gpio_set_cfgpin(SUNXI_GPA(2), SUNIV_GPE_UART0);
    sunxi_gpio_set_cfgpin(SUNXI_GPA(3), SUNIV_GPE_UART0);
    sunxi_gpio_set_pull(SUNXI_GPA(3), SUNXI_GPIO_PULL_UP);
之前花了一点时间改了一下,希望帮得上忙
#3 2020-04-03 11:27:59
ubuntu
已发帖子: 233
这个文件 include/configs/suniv.h 还得加上:
#define CONFIG_CONS_INDEX       1  //UART0
#define CONFIG_CONS_INDEX       2  //UART1
#define CONFIG_CONS_INDEX       3  //UART2
参考: https://whycan.cn/t_1417.html
#4 2020-04-03 11:41:37
ubuntu
已发帖子: 233
diff --git a/arch/arm/dts/suniv.dtsi b/arch/arm/dts/suniv.dtsi
index 10da83b53a..9dd95f38e1 100644
--- a/arch/arm/dts/suniv.dtsi
+++ b/arch/arm/dts/suniv.dtsi
@@ -125,6 +125,16 @@
                                function = "uart0";
+                       uart1_pins_a: uart-pins-pa {
+                               pins = "PA2", "PA3";
+                               function = "uart1";
+                       uart2_pins_a: uart-pins-pe-uart2 {
+                               pins = "PE7", "PE8";
+                               function = "uart2";
                timer@1c20c00 {
diff --git a/arch/arm/include/asm/arch-sunxi/gpio.h b/arch/arm/include/asm/arch-sunxi/gpio.h
index b0a946d3b7..09c1a78adc 100644
--- a/arch/arm/include/asm/arch-sunxi/gpio.h
+++ b/arch/arm/include/asm/arch-sunxi/gpio.h
@@ -176,6 +176,9 @@ enum sunxi_gpio_number {
 #define SUNXI_GPD_LVDS0                3
 #define SUNIV_GPE_UART0                5
+#define SUNIV_GPA_UART1                5
+#define SUNIV_GPE_UART2                3
 #define SUN5I_GPE_SDC2         3
 #define SUN8I_GPE_TWI2         3
diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c
index 6afbb7affa..7a44996505 100644
--- a/arch/arm/mach-sunxi/board.c
+++ b/arch/arm/mach-sunxi/board.c
@@ -87,6 +87,14 @@ static int gpio_init(void)
        sunxi_gpio_set_cfgpin(SUNXI_GPE(0), SUNIV_GPE_UART0);
        sunxi_gpio_set_cfgpin(SUNXI_GPE(1), SUNIV_GPE_UART0);
        sunxi_gpio_set_pull(SUNXI_GPE(1), SUNXI_GPIO_PULL_UP);
+#elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUNIV)
+       sunxi_gpio_set_cfgpin(SUNXI_GPA(2), SUNIV_GPA_UART1);
+       sunxi_gpio_set_cfgpin(SUNXI_GPA(3), SUNIV_GPA_UART1);
+       sunxi_gpio_set_pull(SUNXI_GPA(3), SUNXI_GPIO_PULL_UP);
+#elif CONFIG_CONS_INDEX == 3 && defined(CONFIG_MACH_SUNIV)
+       sunxi_gpio_set_cfgpin(SUNXI_GPE(7), SUNIV_GPE_UART2);
+       sunxi_gpio_set_cfgpin(SUNXI_GPE(8), SUNIV_GPE_UART2);
+       sunxi_gpio_set_pull(SUNXI_GPA(8), SUNXI_GPIO_PULL_UP);
 #elif CONFIG_CONS_INDEX == 1 && (defined(CONFIG_MACH_SUN4I) || \
                                 defined(CONFIG_MACH_SUN7I) || \
                                 defined(CONFIG_MACH_SUN8I_R40))
diff --git a/include/configs/suniv.h b/include/configs/suniv.h
index cadb003f02..b1448f49d4 100644
--- a/include/configs/suniv.h
+++ b/include/configs/suniv.h
@@ -29,4 +29,7 @@
 #define CONFIG_HIDE_LOGO_VERSION
+#undef CONFIG_CONS_INDEX
+#define CONFIG_CONS_INDEX       3
 #endif /* __CONFIG_H */
从 UART2(PE7/PE8)输出,  刚刚改完, 还没测试呢, 可能有坑。
#5 2020-04-03 15:22:13
ubuntu
已发帖子: 233
改这个只能影响u-boot 的 spl 串口输出, 如果u-boot输出还得改 dts 文件:
diff --git a/arch/arm/dts/suniv-f1c100s-licheepi-nano.dts b/arch/arm/dts/suniv-f1c100s-licheepi-nano.dts
index 9c111e6228..45658d2b1d 100644
--- a/arch/arm/dts/suniv-f1c100s-licheepi-nano.dts
+++ b/arch/arm/dts/suniv-f1c100s-licheepi-nano.dts
@@ -15,11 +15,12 @@
        aliases {
                serial0 = &uart0;
+               serial2 = &uart2;
                spi0 = &spi0;
        chosen {
-               stdout-path = "serial0:115200n8";
+               stdout-path = "serial2:115200n8";
@@ -47,6 +48,18 @@
        status = "okay";
+&uart1 {
+       pinctrl-names = "default";
+       pinctrl-0 = <&uart1_pins_a>;
+       status = "okay";
+&uart2 {
+       pinctrl-0 = <&uart2_pins_e>;
+       status = "okay";
 &usb_otg {
        dr_mode = "otg";
        status = "okay";
index 10da83b53a..d3b937a16d 100644
                                function = "uart0";
+                       uart2_pins_e: uart-pins-pe-uart2 {
                timer@1c20c00 {
@@ -29,4 +29,7 @@
从 UART2(PE7/PE8)输出搞定!
楼主 #6 2020-04-03 21:47:09
迪卡
所在地: 河北
已发帖子: 916
谢谢各位大哥,uboot串口解决了,接下来,改内核的串口。
楼主 #7 2020-04-03 22:09:10
迪卡
所在地: 河北
已发帖子: 916
只更改rootfs中的/etc/inittab里的还是不行,只停在start kernel
#8 2020-04-16 15:52:13
lihanchao90
和u-boot 类似修改dts
diff --git a/arch/arm/boot/dts/suniv-f1c100s-licheepi-nano.dts b/arch/arm/boot/dts/suniv-f1c100s-licheepi-nano.dts
index f46e190..c31e4ea 100644
--- a/arch/arm/boot/dts/suniv-f1c100s-licheepi-nano.dts
+++ b/arch/arm/boot/dts/suniv-f1c100s-licheepi-nano.dts
@@ -7,7 +7,8 @@
 #include "suniv-f1c100s.dtsi"
 #include <dt-bindings/gpio/gpio.h>
+#include <dt-bindings/input/input.h>
+#include <dt-bindings/interrupt-controller/irq.h>
 	model = "Lichee Pi Nano";
 	compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s",
@@ -15,11 +16,12 @@
 	aliases {
 		serial0 = &uart0;
+		serial1 = &uart1;
 		spi0 = &spi0;
 	chosen {
+		stdout-path = "serial1:115200n8";
 	panel: panel {
@@ -67,13 +69,52 @@
 	pinctrl-0 = <&spi0_pins_a>;
 	status = "okay";
-	flash@0 {
+	spi-max-frequency = <50000000>;
+	flash: w25q128@0 {
 		#address-cells = <1>;
 		#size-cells = <1>;
 		compatible = "winbond,w25q128", "jedec,spi-nor";
 		reg = <0>;
-		spi-max-frequency = <40000000>;
+		partitions {
+		    compatible = "fixed-partitions";
+		    #address-cells = <1>;
+		    #size-cells = <1>;
+		    partition@0 {
+				label = "u-boot";
+				reg = <0x000000 0x100000>;
+				read-only;
+			partition@100000 {
+			label = "dtb";
+			reg = <0x100000 0x10000>;
+			read-only;
+			partition@110000 {
+			label = "kernel";
+			reg = <0x110000 0x400000>;
+			read-only;
+			partition@510000 {
+			label = "rootfs";
+			reg = <0x510000 0xAF0000>;
+&i2c0 {
+	pinctrl-0 = <&i2c0_pins>;
+	status = "okay";
+	ns2009: ns2009@48 {
+		compatible = "nsiway,ns2009";
+		reg = <0x48>;
@@ -95,7 +136,11 @@
 	pinctrl-0 = <&uart0_pins_a>;
 	status = "okay";
+&uart1 {
+	status = "okay";
 &usb_otg {
 	dr_mode = "otg";
 	status = "okay";
diff --git a/arch/arm/boot/dts/suniv.dtsi b/arch/arm/boot/dts/suniv.dtsi
index ee600cd..d0d2fc7 100644
--- a/arch/arm/boot/dts/suniv.dtsi
+++ b/arch/arm/boot/dts/suniv.dtsi
@@ -228,12 +228,18 @@
 				       "PD20", "PD21";
 				function = "lcd";
+			i2c0_pins: i2c0 {
+				pins = "PD12", "PD0";
+                    		function = "i2c0";
 				function = "uart0";
 			mmc0_pins: mmc0-pins {
 				pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
 				function = "mmc0";
@@ -284,6 +290,18 @@
 			resets = <&ccu RST_BUS_UART2>;
 			status = "disabled";
+		i2c0: i2c@1c27000 {
+			compatible = "allwinner,sun6i-a31-i2c";
+			reg = <0x01C27000 0x400>;
+			interrupts = <7>;
+			clocks = <&ccu CLK_BUS_I2C0>;
+			resets = <&ccu RST_BUS_I2C0>;
+			status = "disabled";
+			#size-cells = <0>;
 		usb_otg: usb@1c13000 {
 			compatible = "allwinner,suniv-musb";
diff --git a/drivers/mtd/spi-nor/spi-nor.c b/drivers/mtd/spi-nor/spi-nor.c
index bc266f7..99dc551 100644
--- a/drivers/mtd/spi-nor/spi-nor.c
+++ b/drivers/mtd/spi-nor/spi-nor.c
@@ -1182,7 +1182,7 @@ static const struct flash_info spi_nor_ids[] = {
 	{ "w25q80", INFO(0xef5014, 0, 64 * 1024,  16, SECT_4K) },
 	{ "w25q80bl", INFO(0xef4014, 0, 64 * 1024,  16, SECT_4K) },
-	{ "w25q128", INFO(0xef4018, 0, 64 * 1024, 256, SECT_4K) },
+	{ "w25q128", INFO(0xef4018, 0, 64 * 1024, 256, 0) },
 	{ "w25q256", INFO(0xef4019, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
 	{ "w25m512jv", INFO(0xef7119, 0, 64 * 1024, 1024,
 			SECT_4K | SPI_NOR_QUAD_READ | SPI_NOR_DUAL_READ) },
#9 2020-04-17 11:23:33
MK-2020
已发帖子: 51
U-BOOT改好了,参数好像会直接传递到内核,所以内核那边是不需要去改的。只停在start kernel可能是原来传递的是ttyS0,你没改到ttyS1.
#10 2021-11-29 20:17:21
somnus
已发帖子: 17
  • 不通过:其他
#11 2021-11-30 12:25:38
zh_tao518
MK-2020 说:
应该是正解
#12 2022-03-17 15:48:24
Sam
已发帖子: 55
@迪卡
能分享下教程么?我想我串口2打印日志,BSP LINUX3.10 修改fex文件和uboot都不好使,现在想用主线UBOOT引导BSP来实现,但是不知道怎么实现
#14 2023-12-22 13:54:26
wei
迪卡 说:
后来解决了吗
#15 2024-03-02 23:22:56
future
已发帖子: 43
楼主可以整理一下主线u-boot修改的步骤吗。
