楼主 #1 2017-11-11 17:11:58
Allwinner全志V3s板子用ns2009驱动电阻触摸屏,在荔枝派zero工作好好的软件,我的板子出这个错误:
[   13.046734] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[   13.053285] input input1: Poll touch data failed: -110
[   15.206667] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[   15.213230] input input1: Poll touch data failed: -110
[   17.366664] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[   17.373225] input input1: Poll touch data failed: -110
[   19.526660] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[   19.533223] input input1: Poll touch data failed: -110
[   21.686660] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[   21.693220] input input1: Poll touch data failed: -110
[   23.846663] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[   23.853220] input input1: Poll touch data failed: -110
#2 2017-11-14 14:19:34
沉鱼
已发帖子: 161
Re: Allwinner全志V3s板子用ns2009驱动电阻触摸屏,在荔枝派zero工作好好的软件,我的板子出这个错误:
硬件与荔枝派zero 一样?
I2C SCK/SDA 有没有上拉?
楼主 #3 2017-11-14 14:22:19
果然是没有上拉, 这坑挖大了。
我去飞线试一试。
楼主 #4 2017-11-14 14:24:49
飞线就好了,谢谢大神.
#5 2018-07-18 10:48:20
yangbo
请问一下,我不用触摸屏,如果关闭上面的错误提示,我是用buildroot编译的,在make menuconfig里面去掉了tslib,现在改怎么办?谁知道回复一下,谢谢
#6 2018-07-18 11:11:37
已发帖子: 9,252
在设备树里面删除 ns2009 即可
打开 arch/arm/boot/dts/sun8i-v3s-licheepi-zero.dts
删除:
&i2c0 {
    status = "okay";
    ns2009: ns2009@48 {
        compatible = "nsiway,ns2009";
        reg = <0x48>;
重新编译出 dtb 文件, 烧录.
#7 2018-07-18 11:23:07
yangbo
谢谢了,
#8 2020-10-26 17:08:22
jkl
已发帖子: 254
daydayup 说:
请问一下,我现在遇到同样的问题,上拉也给安排上了,但是还是一样的错误,这是怎么回事?
   89.440754] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[   91.520754] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[   93.600759] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[   95.680755] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[   97.760754] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[   99.840761] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  101.920755] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  104.000756] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  106.080762] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  108.160756] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  110.240753] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  112.320752] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  114.400754] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  116.480753] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  118.560753] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  120.640759] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  122.720753] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  124.800754] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  126.880759] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  128.960754] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  131.040755] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  133.120759] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  135.200755] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  137.280757] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  139.361038] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
最近编辑记录 jkl (2020-10-26 17:14:20)
#9 2022-10-31 15:01:00
Chin
已发帖子: 61
@jkl
是不是上拉没起作用?
