楼主 #1 2017-11-25 10:02:28
已发帖子: 9,250
荔枝派Zero V3s开发板驱动 ili9341 摆拍
参考: Lichee Pi zero SPI LCD使用指南
在阅读本文之前,首先要保证你能够成功的编译linux内核,并构建一个完整的根文件系统。关于这部分的知识,之后还会单独写一个文档讨论。
其实lichee pi zero使用的4.10内核已经包含了市面上常见的SPI液晶屏的驱动(fbtft),我们所要做的仅仅是在设备树中添加节点。说起这个fbtft,它之前独立于内核存在过一段时间,作为单独的代码文件发布,如果你需要它,可以手动把这部分文件复制到内核源码中(参考fbtft的 github仓库)。后来被并入内核,具体是在哪一个版本的被并入内核的,这个也不必深究了。不过目前为止fbtft并未转正,依然存放在drivers/staging目录中。
1 配置内核添加fbtft驱动
使用make menuconfig配置内核,加入ili9341驱动。fbtft还支持更多型号的SPI总线的液晶屏。关于支持列表这里就不一一列出,可以进入menuconfig中查看。
Device Drivers  --->
    [ * ] Staging drivers  --->
        <*>   Support for small TFT LCD display modules  --->
                <*>   FB driver for the ILI9341 LCD Controller
                <*>   Generic FB driver for TFT LCD displays
编译内核:
make -j4
2 修改设备树注册ili9341
lichee pi zero默认注册40Pin RGB液晶屏,并且在启动参数中设置console为tty0 。为了尽可能减少改动,我们在设备树中删除了默认的40Pin液晶屏,这样新添加的ili9341也就顺利成章的成了唯一的太子,启动时的信息会通过他显示。
下面是使用git对比改动前后的细节:
diff --git a/arch/arm/boot/dts/sun8i-v3s-licheepi-zero.dts b/arch/arm/boot/dts/sun8i-v3s-licheepi-zero.dts
index 929a79e..9c91f75 100644
--- a/arch/arm/boot/dts/sun8i-v3s-licheepi-zero.dts
+++ b/arch/arm/boot/dts/sun8i-v3s-licheepi-zero.dts
@@ -90,3 +90,21 @@
        usb0_id_det-gpio = <&pio 5 6 GPIO_ACTIVE_HIGH>;
        status = "okay";
+&spi0 {
+       status = "okay";
+       ili9341@0 {
+               compatible = "ilitek,ili9341";
+               reg = <0>;
+               spi-max-frequency = <15000000>;
+               rotate = <270>;
+               bgr;
+               fps = <10>;
+               buswidth = <8>;
+               reset-gpios = <&pio 1 7 GPIO_ACTIVE_LOW>;
+               dc-gpios = <&pio 1 5 GPIO_ACTIVE_LOW>;
+               debug = <0>;
diff --git a/arch/arm/boot/dts/sun8i-v3s.dtsi b/arch/arm/boot/dts/sun8i-v3s.dtsi
index 50b8788..b0eb22e 100644
--- a/arch/arm/boot/dts/sun8i-v3s.dtsi
+++ b/arch/arm/boot/dts/sun8i-v3s.dtsi
@@ -54,15 +54,6 @@
                #address-cells = <1>;
                #size-cells = <1>;
                ranges;
-               simplefb_lcd: framebuffer@0 {
-                       compatible = "allwinner,simple-framebuffer",
-                                    "simple-framebuffer";
-                       allwinner,pipeline = "de0-lcd0";
-                       clocks = <&ccu CLK_BUS_TCON0>, <&ccu CLK_BUS_DE>,
-                                <&ccu CLK_DE>, <&ccu CLK_TCON0>;
-                       status = "disabled";
注:
在设备树中,PA对应&pio 0, PB对应&pio 1, 以此类推。因此dc-gpios实际表示的是PB5,也就是zero丝印上的PWM1。
如果我的屏幕的RESET引脚连接了高电平,或者接了一个RC回路作为上电复位的信号,那么这里的复位引脚是不是可以不指定呢?
这样也是不可以的。因为在程序中,首先读取reset-gpios,若reset-gpios在设备树中不存在,那么直接忽略其余的信号。这样导致无法控制最关键的dc-gpios引脚。因此至少在不更改程序的前提下,这条信号是一定要写上的。
static int fbtft_request_gpios_dt(struct fbtft_par *par)
    int i;
    int ret;
    if (!par->info->device->of_node)
        return -EINVAL;
    ret = fbtft_request_one_gpio(par, "reset-gpios", 0, &par->gpio.reset);
    if (ret)
        return ret;
    ret = fbtft_request_one_gpio(par, "dc-gpios", 0, &par->gpio.dc);
    if (ret)
        return ret;
3 更新SD卡中的程序
假设你之前已经创建好了一张可以正确启动的SD卡,那么你要做的很简单:
将arch/arm/boot/zImage和arch/arm/boot/dts/sun8i-v3s-licheepi-zero.dtb拷贝到SD卡中的vfat分区,覆盖之前的程序即可。
4 硬件连接
SPI屏    zero
3v3    3v3
GND    GND
DC    PWM1
RST    3v3
CS    CS
CLK    CLK
MISO    MISO
MOSI    MOSI
5 上电启动
linux内核启动时会加载fbtft驱动,注册framebuffer设备,打印如下信息:
[    0.860671] fbtft_of_value: buswidth = 8
[    0.864653] fbtft_of_value: debug = 0
[    0.868325] fbtft_of_value: rotate = 270
[    0.872252] fbtft_of_value: fps = 10
[    1.244063] graphics fb0: fb_ili9341 frame buffer, 320x240, 150 KiB video memory, 16 KiB DMA buffer memory, fps=10, spi32766.0 at 15 MHz
显示效果如下图:
楼主 #2 2017-11-25 10:05:10
已发帖子: 9,250
Re: 荔枝派Zero V3s开发板驱动 ili9341 摆拍
写入随机数到屏幕:
Qt自带钟表demo:
mplayer播放:
mplayer播放:
#3 2017-12-09 10:24:28
Wang
已发帖子: 13
新入坑的小白请教,static int fbtft_request_gpios_dt(struct fbtft_par *par)这个函数是添加到哪里
楼主 #4 2017-12-09 11:10:43
已发帖子: 9,250
Wang 说:
这个是驱动已经有了的, 不需要添加, 你找到驱动文件。
https://github.com/notro/fbtft/blob/master/fbtft-core.c
#5 2022-04-10 13:23:44
stutian
make menuconfig同样配置为什么启动时没有显示如上log信息???
#6 2022-07-31 23:02:11
tevada2010
已发帖子: 54
cat /dev/urandom > /dev/fb0
使用第一条命令可以让屏幕出现雪花
cat /dev/zero > /dev/fb0
使用第二条命令可以让屏幕变黑
为什么我看不到图片显示?
最近编辑记录 tevada2010 (2022-08-01 19:28:53)
#7 2022-08-05 21:43:46
hahahah
我参考你的设备树发现不行
#8 2022-08-11 16:00:49
nicholas3388
cat /dev/urandom > /dev/fb0 执行这个命令后,提示cat: write error: No space left on device  怎么破?
空间还是有的
# df -h
Filesystem                Size      Used Available Use% Mounted on
/dev/root                28.5G     10.8M     27.0G   0% /
devtmpfs                 26.9M         0     26.9M   0% /dev
tmpfs                    27.4M         0     27.4M   0% /dev/shm
tmpfs                    27.4M     16.0K     27.4M   0% /tmp
tmpfs                    27.4M     16.0K     27.4M   0% /run
最近编辑记录 nicholas3388 (2022-08-11 16:04:00)
#9 2022-08-11 20:08:31
tevada2010
已发帖子: 54
@nicholas3388
现在可以显示图像。
但是想从开机进入系统开始显示,还是做不到
还是做不到下图。
#10 2022-08-12 09:54:00
nicholas3388
@tevada2010
同问,上电时怎么同步打印出那些log信息?
上电信息
最近编辑记录 nicholas3388 (2022-08-12 09:55:23)
#11 2022-08-12 10:46:34
司徒
Moderator
已发帖子: 547
@tevada2010 @nicholas3388
要使用 framebuffer console, 兩個部分需要:
1. UBoot 傳遞 console=tty0 訊息 (或者 kernel hardcode 這個訊息)
2. Kernel 必須開啟支援 Device Drivers > Graphics support > Console display driver support > Framebuffer Console Support
Ref: https://steward-fu.github.io/website/mcu/nuc972/framebuffer_console.htm
#12 2022-08-12 21:30:01
tevada2010
已发帖子: 54
@司徒
Thank you very much. Compleat
297764346_812442516451941_3969007583404091572_n.jpg297572295_757286112187945_5308810038688664791_n.jpg
#13 2022-08-29 16:32:23
bobrey
@nicholas3388
请问这个是咋回事呢,我现在使用 荔枝派nano配置ili9341也是出现这个问题;
# cat /dev/urandom > /dev/fb0
# df -h
/dev/root                28.5G    558.3M     26.5G   2% /
devtmpfs                 11.6M         0     11.6M   0% /dev
tmpfs                    12.1M         0     12.1M   0% /dev/shm
tmpfs                    12.1M         0     12.1M   0% /tmp
tmpfs                    12.1M      8.0K     12.1M   0% /run
#14 2022-09-04 16:45:36
744219909
已发帖子: 31
@bobrey
是正常的
#15 2022-11-02 11:46:04
akisasaki
你好,我现在遇到了屏幕显示不完整的错误,你知道是怎么回事吗?
设备树信息如下:
    lcd:tftlcd2-8@0{
        spi-cpol;//spi模式
        spi-cpha;
        status = "okay";
        rotate = <90>;//使屏幕旋转90度,相较于默认显示角度
        fps = <30>;//帧率
        buswidth = <8>;//数据位宽
        rgb;
        cs-gpios = <&pio 0 7 GPIO_ACTIVE_LOW>;  //PA7
        reset-gpios = <&pio 0 8 GPIO_ACTIVE_LOW> ;//PA8
        dc-gpios = <&pio 0 9 GPIO_ACTIVE_LOW> ;//PA9
        reg = <0>;  //SPI NO address
        spi-max-frequency = <42000000>; //4.2MB
驱动是正常的,能够全屏显示雪花,就是打印uboot和内核启动信息的时候不能完整显示,总会有企鹅logo在上面
