楼主 # 2022-06-15 11:18:56
jkl
已发帖子: 256
全志tina,display驱动模块中dev_fb.c文件中,Fb_map_kernel_logo函数中:
paddr = bootlogo_addr; =====》 这个地址从哪里得到呀,那来的呀??
static int Fb_map_kernel_logo(u32 sel, struct fb_info *info)
    void *vaddr = NULL;
    uintptr_t paddr = 0;
    void *screen_offset = NULL, *image_offset = NULL;
    char *tmp_buffer = NULL;
    char *bmp_data = NULL;
    struct sunxi_bmp_store s_bmp_info;
    struct sunxi_bmp_store *bmp_info = &s_bmp_info;
    struct bmp_pad_header bmp_pad_header;
    struct bmp_header *bmp_header;
    int zero_num = 0;
    unsigned int x, y, bmp_bpix, fb_width, fb_height;
    unsigned int effective_width, effective_height;
    uintptr_t offset;
    int i = 0;
    struct disp_manager *mgr;
    mgr = g_disp_drv.mgr[sel];
    if (paddr == 0) {
        __inf("Fb_map_kernel_logo failed!");
        return Fb_copy_boot_fb(sel, info);
    printk("%s%d%s\n",__FILE__,__LINE__,__FUNCTION__);
    /* parser bmp header */
    offset = paddr & ~PAGE_MASK;
    vaddr = (void *)Fb_map_kernel(paddr, sizeof(struct bmp_header));
    if (vaddr == NULL) {
        __wrn("fb_map_kernel failed, paddr=0x%p,size=0x%x\n",
              (void *)paddr, (unsigned int)sizeof(struct bmp_header));
        return -1;
    memcpy(&bmp_pad_header.signature[0], vaddr + offset,
    bmp_header = (struct bmp_header *) &bmp_pad_header.signature[0];
    if ((bmp_header->signature[0] != 'B')
        || (bmp_header->signature[1] != 'M')) {
        Fb_unmap_kernel(vaddr);
#if defined(CONFIG_DECOMPRESS_LZMA)
        return lzma_decode(paddr, info);
#else
        __wrn("this is not a bmp picture.\n");
        return -1;
    bmp_bpix = bmp_header->bit_count / 8;
    if ((bmp_bpix != 3) && (bmp_bpix != 4))
        return -1;
    x = bmp_header->width;
    y = (bmp_header->height & 0x80000000) ? (-bmp_header->
                         height) : (bmp_header->height);
    if (bmp_bpix == 3) {
        zero_num = (4 - ((3 * x) % 4)) & 3;
#ifndef SUPPORT_ROTATE
        /*uboot have removed zero for us*/
        zero_num = 0;
    fb_width = info->var.xres;
    fb_height = info->var.yres;
    if ((paddr <= 0) || x <= 1 || y <= 1) {
        __wrn("kernel logo para error!\n");
        return -EINVAL;
    bmp_info->x = x;
    bmp_info->y = y;
    bmp_info->bit = bmp_header->bit_count;
    bmp_info->buffer = (void *__force)(info->screen_base);
    if (bmp_bpix == 3)
        info->var.bits_per_pixel = 24;
    else if (bmp_bpix == 4)
        info->var.bits_per_pixel = 32;
    /* map the total bmp buffer */
    vaddr =
                  (x * bmp_bpix + zero_num) * y + sizeof(struct bmp_header));
              (void *)paddr,
              (unsigned int)(x * y * bmp_bpix +
               sizeof(struct bmp_header)));
        return -1;
    tmp_buffer = (char *)bmp_info->buffer;
    screen_offset = (void *)bmp_info->buffer;
    bmp_data = (char *)(vaddr + bmp_header->data_offset);
    image_offset = (void *)bmp_data;
    effective_width = (fb_width < x) ? fb_width : x;
    effective_height = (fb_height < y) ? fb_height : y;
    if (bmp_header->height & 0x80000000) {
#if defined(SUPPORT_ROTATE)
        if (info->var.bits_per_pixel == 24) {
            screen_offset =
                (void *)((void *__force)info->screen_base +
                     (fb_width * (abs(fb_height - y) / 2)
                      + abs(fb_width - x) / 2)
                     * 4);
            rgb24_to_rgb32(image_offset, bmp_header, info,
                       screen_offset, zero_num);
        } else
        screen_offset =
                 * (info->var.bits_per_pixel >> 3));
            for (i = 0; i < effective_height; i++) {
                memcpy((void *)screen_offset, image_offset,
                       effective_width *
                screen_offset =
                    (void *)(screen_offset + fb_width *
                image_offset =
                    (void *)image_offset +
                    x * (info->var.bits_per_pixel >> 3);
    } else {
            screen_offset =
                     * 4);
            image_offset =
                (void *)bmp_data +
                (effective_height - 1) * (x * 3 + zero_num);
        } else
            screen_offset =
            image_offset =
                (void *)bmp_data + (effective_height -
                            1) * x *
            for (i = effective_height - 1; i >= 0; i--) {
                       effective_width *
                screen_offset =
                         fb_width *
                image_offset =
                    (void *)bmp_data +
                    i * x * (info->var.bits_per_pixel >> 3);
#1 2022-06-15 13:45:12
jjldc
已发帖子: 21
Re: 全志tina,display驱动模块中dev_fb.c文件中,Fb_map_kernel_logo函数中:
uboot在bootm还是disp_bmp的时候,会更新fdt里的/soc/disp下面属性,会更新bootargs启动参数,显存地址和大小好像是通过bootargs传递给内核的
楼主 #2 2022-06-15 14:26:22
jkl
已发帖子: 256
jjldc 说:
这个地址该怎样去确定,就是这个地址的值怎样去确定呢?bmp图片放置的地址
我看display驱动模块里面,logo的显示就是在这一块实现的
最近编辑记录 jkl (2022-06-15 14:30:38)
#3 2022-06-16 08:56:53
jjldc
已发帖子: 21
@jkl
好像是uboot自动分配的地址
