楼主 # 2022-11-03 17:32:52
khalilchen
SWMS4S LCD RGB565驱动
使用了SWMS4S 的SRAMC,代码如下
void lcd_memory_init(void)
    SDRAM_InitStructure SDRAM_InitStruct;
    PORT_Init(PORTM, PIN13, PORTM_PIN13_SDR_CLK, 0);
    PORT_Init(PORTM, PIN14, PORTM_PIN14_SDR_CKE, 0);
    PORT_Init(PORTB, PIN7,  PORTB_PIN7_SDR_WE,   0);
    PORT_Init(PORTB, PIN8,  PORTB_PIN8_SDR_CAS,  0);
    PORT_Init(PORTB, PIN9,  PORTB_PIN9_SDR_RAS,  0);
    PORT_Init(PORTB, PIN10, PORTB_PIN10_SDR_CS,  0);
    PORT_Init(PORTE, PIN15, PORTE_PIN15_SDR_BA0, 0);
    PORT_Init(PORTE, PIN14, PORTE_PIN14_SDR_BA1, 0);
    PORT_Init(PORTN, PIN14, PORTN_PIN14_SDR_A0,  0);
    PORT_Init(PORTN, PIN13, PORTN_PIN13_SDR_A1,  0);
    PORT_Init(PORTN, PIN12, PORTN_PIN12_SDR_A2,  0);
    PORT_Init(PORTN, PIN11, PORTN_PIN11_SDR_A3,  0);
    PORT_Init(PORTN, PIN10, PORTN_PIN10_SDR_A4,  0);
    PORT_Init(PORTN, PIN9,  PORTN_PIN9_SDR_A5,   0);
    PORT_Init(PORTN, PIN8,  PORTN_PIN8_SDR_A6,   0);
    PORT_Init(PORTN, PIN7,  PORTN_PIN7_SDR_A7,   0);
    PORT_Init(PORTN, PIN6,  PORTN_PIN6_SDR_A8,   0);
    PORT_Init(PORTN, PIN3,  PORTN_PIN3_SDR_A9,   0);
    PORT_Init(PORTN, PIN15, PORTN_PIN15_SDR_A10, 0);
    PORT_Init(PORTN, PIN2,  PORTN_PIN2_SDR_A11,  0);
    PORT_Init(PORTM, PIN15, PORTM_PIN15_SDR_A12, 0);
    PORT_Init(PORTE, PIN7,  PORTE_PIN7_SDR_D0,   1);
    PORT_Init(PORTE, PIN6,  PORTE_PIN6_SDR_D1,   1);
    PORT_Init(PORTE, PIN5,  PORTE_PIN5_SDR_D2,   1);
    PORT_Init(PORTE, PIN4,  PORTE_PIN4_SDR_D3,   1);
    PORT_Init(PORTE, PIN3,  PORTE_PIN3_SDR_D4,   1);
    PORT_Init(PORTE, PIN2,  PORTE_PIN2_SDR_D5,   1);
    PORT_Init(PORTE, PIN1,  PORTE_PIN1_SDR_D6,   1);
    PORT_Init(PORTE, PIN0,  PORTE_PIN0_SDR_D7,   1);
    PORT_Init(PORTE, PIN8,  PORTE_PIN8_SDR_D8,   1);
    PORT_Init(PORTE, PIN9,  PORTE_PIN9_SDR_D9,   1);
    PORT_Init(PORTE, PIN10, PORTE_PIN10_SDR_D10, 1);
    PORT_Init(PORTE, PIN11, PORTE_PIN11_SDR_D11, 1);
    PORT_Init(PORTE, PIN12, PORTE_PIN12_SDR_D12, 1);
    PORT_Init(PORTE, PIN13, PORTE_PIN13_SDR_D13, 1);
    PORT_Init(PORTC, PIN14, PORTC_PIN14_SDR_D14, 1);
    PORT_Init(PORTC, PIN15, PORTC_PIN15_SDR_D15, 1);
    PORT_Init(PORTB, PIN6,  PORTB_PIN6_SDR_LDQM, 0);
    PORT_Init(PORTM, PIN12, PORTM_PIN12_SDR_UDQM,0);
    SDRAM_InitStruct.Size = SDRAM_SIZE_8MB;
    SDRAM_InitStruct.ClkDiv = SDRAM_CLKDIV_1;
    SDRAM_InitStruct.CASLatency = SDRAM_CASLATENCY_2;
    SDRAM_InitStruct.TimeTRP  = SDRAM_TRP_3;
    SDRAM_InitStruct.TimeTRCD = SDRAM_TRCD_3;
    SDRAM_InitStruct.TimeTRFC  = SDRAM_TRFC_15;
    SDRAM_Init(&SDRAM_InitStruct);
LV_HOR_RES_MAX 为屏幕宽度
LV_VER_RES_MAX  为屏幕长度
extern uint32_t lcdbuf_show[LV_HOR_RES_MAX * LV_VER_RES_MAX / 2];
void lcd_rgb_init(void)
    uint32_t i;
    LCD_InitStructure LCD_initStruct;
    PORT_Init(PORTC, PIN9,  PORTC_PIN9_LCD_R3,  0);
    PORT_Init(PORTC, PIN10, PORTC_PIN10_LCD_R4, 0);
    PORT_Init(PORTC, PIN11, PORTC_PIN11_LCD_R5, 0);
    PORT_Init(PORTC, PIN12, PORTC_PIN12_LCD_R6, 0);
    PORT_Init(PORTC, PIN13, PORTC_PIN13_LCD_R7,  0);
    PORT_Init(PORTA, PIN14, PORTA_PIN14_LCD_G2,  0);
    PORT_Init(PORTA, PIN15, PORTA_PIN15_LCD_G3, 0);
    PORT_Init(PORTC, PIN0, PORTC_PIN0_LCD_G4, 0);
    PORT_Init(PORTC, PIN1, PORTC_PIN1_LCD_G5, 0);
    PORT_Init(PORTC, PIN2, PORTC_PIN2_LCD_G6, 0);
    PORT_Init(PORTC, PIN3, PORTC_PIN3_LCD_G7, 0);
    PORT_Init(PORTB, PIN15, PORTB_PIN15_LCD_B3, 0);
//    PORT_Init(PORTA, PIN2,  PORTA_PIN2_LCD_B4,  0);
    PORT_Init(PORTA, PIN9,  PORTA_PIN9_LCD_B5,  0);
    PORT_Init(PORTA, PIN10, PORTA_PIN10_LCD_B6,  0);
    PORT_Init(PORTA, PIN11, PORTA_PIN11_LCD_B7,  0);
    PORT_Init(PORTB, PIN2,  PORTB_PIN2_LCD_VSYNC, 0);
    PORT_Init(PORTM, PIN8,  PORTM_PIN8_LCD_HSYNC, 0);
    PORT_Init(PORTM, PIN11, PORTM_PIN11_LCD_DEN,   0);
    PORT_Init(PORTB, PIN5,  PORTB_PIN5_LCD_DCLK,  0);
    LCD_initStruct.ClkDiv = 6;
    LCD_initStruct.Format = LCD_FMT_RGB565;
    LCD_initStruct.HnPixel = 480;
    LCD_initStruct.VnPixel = 272;
    LCD_initStruct.Hfp = 5;
    LCD_initStruct.Hbp = 40;
    LCD_initStruct.Vfp = 8;
    LCD_initStruct.Vbp = 8;
    LCD_initStruct.HsyncWidth = 5;
    LCD_initStruct.VsyncWidth = 5;
    LCD_initStruct.DataSource = (uint32_t)lcdbuf_show;
    LCD_initStruct.Background = 0xFFFF;
    LCD_initStruct.SampleEdge = LCD_SAMPLE_FALL;    // ATK-4342 RGBLCD 下降沿采样
    LCD_initStruct.IntEOTEn = 1;
    LCD_Init(LCD, &LCD_initStruct);
    LCD_Start(LCD);
    memset(lcdbuf_show, 0, sizeof(lcdbuf_show));
void LCD_Handler(void)
    LCD_INTClr(LCD);
    LCD_Start(LCD);
#1 2022-11-03 18:40:24
Iven
已发帖子: 61
Re: SWMS4S LCD RGB565驱动
这个是全志SOC?
#2 2022-11-03 19:00:55
tomyqg
已发帖子: 48
他家咋不出个带以太网,内置sdram的片子啊,还有xip功能有待加强
最近编辑记录 tomyqg (2022-11-03 19:01:13)
#3 2022-11-04 11:07:45
LinjieGuo
Moderator
已发帖子: 569
分类搞错了,要放到华芯微特区。
#4 2022-11-04 13:31:03
Iven
已发帖子: 61
这个芯片型号都写错了,忒不专业
楼主 #5 2022-11-22 09:40:58
khalilchen
因为之前没发过贴,只是随便弄了一点上来水一水的:D
